Air conditioner resistance - Heating & Cooling
  • 583 Answers
  • 410 Answers
Could you clarify what resistance you are needing? or maybe tell me what problem you are having and we can start from square one. thanks peyton
Posted on Mar 05, 2009
    Genius:
  • 1,269 Answers
Can you please tell the main problem on your unit? Thanks!
  • 19,396 Answers
Please give me the model number and more detail on the part you need.
How do I remove outer casing of my p210r32 air conditioner
remove screws from panel , it mar require tamper resistant tool kit .
Nov 13, 2014 | Soleus 10,000-BTU Portable Air Conditioner...
How to replace a thermister?
A thermister reads temperature by resistance (ohms). Higher the temperature gets the lower the resistance. It is two wires just pull them out and replace. It does not matter if you interchange them. Your unit reads the thermister to determine temperature.
May 28, 2014 | Fujitsu 24R1 Air Conditioner
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
I have a air conditioner and the power cord gets really hot
If it's a 110 window unit the problem is resistance. resistance=heat. Either replace the outlet with a new one and/or replace the plug. '
WARNING: This can cause the wires in you house to get hot enough to melt the insulation and cause a severe fire. Do get this fixed at once!
Oct 21, 2010 | Heating & Cooling
My Air conditioner only works on high
The switch that runs the blower motor for air and heat sends the DC voltage through some big resisters when it isn't set on high. (On high it sends all the power to the motor.)
If the lowest speed doesn't work then one of the resisters has gone bad, or come disconnected. If more than 1 speed doesn't work then a differant resister has gone bad or disconnected. The power runs through each resister in series so the most common one to go bad is the second to highest speed. when this resister is bad thaen it will only work on the highest setting. Replacing the switch won't fix it. You will have to find the resister that is bad and replace it.
The resister bank is usually tucked up behind the dash where only a kid can focus his eyes, and contort himself enough to see it.
Once the resister is replaced it should run perfectly.
Presto.
Aug 26, 2009 | 1998 Mercury Mountaineer
Air conditioner blower motor resister on dodge grand caravan
I have a 2002 Grand Caravan and it is located behind the glovebox. It may be in the same place.
Jul 01, 2008 | 2004 Dodge Grand Caravan
Haier air conditioner
On the Compressor? - Theres a run (R) that gets the red wire from the run capacitor or line side voltage, theres a start (S) that gets the yellow wire from start capacitor and theres a common (C) that gets the black wire which connects to neutral or common. If you ohm it out to identify the terminals the highest resistance is between (S) and (R) second is between (S) and (C) and least resistances is between (R) and (C). Hope this helped. GL!
Jun 14, 2008 | Haier Preference Plus HWR24VCA Air...
Indoor unit comes on for 5 seconds and then shuts down
"Off" the circuit breaker and then "on" again then start the unit .
Oct 08, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
