Question about Sharp NAVITAR 1.2 INCH BUHL LCD LENS, WIDE-ANGLE, Projector Lamp FOR PROJECTORS => Model 825MCL01
How do I make my projector image "square"?
I have several training rooms with projectors. Some look nice and square...some are way off. How do I fix this?
  • 37 Answers
I Believe you need to go into the projectors settings and adjust what is called the keystone, this changes the tilt effect that the projector throws, just keep messing with that setting until you get it how you like it.
Posted on Jul 12, 2009
Time to change bulb??
Check the lamp. It might be faulty. [low light intensity]
May 11, 2012 | Vivitek D732MX DLP Projector, 3200 ANSI...
The projector is not giving a bright picture. The image on the wall is very dim
I you were using the projector in the same room with the same ambient light and if you notice this problem try increasing brightness, if still the brightness is not sufficient then it is time to replace the projector lamp.
If you have moved your projector to a different place, check if the existing light / ambient light in that room is making the image look dull / not so bright. If this is the case, try to reduce the ambient light
Mar 09, 2011 | Dell 1100MP Multimedia Projector
Laptop screen image is truncated on data projector display (Dell)
Had the same problem, tried a Factory Reset from the menu and it seems to have worked. Don't know what caused in in the first place
Nov 11, 2009 | Dell Office Equipment & Supplies
Image upside down
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
May 15, 2009 | Optoma / CTX EzPro 610H / 615H Replacement...
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
How do I make my projector image square??
is the projector in the center , how is the angle
Mar 04, 2009 | Sharp NAVITAR 1.2 INCH BUHL LCD LENS,...
Display of image between laptop and projector
change the resolution. the desktop is too big.
Nov 09, 2008 | LG DLP Projector 1400Lum RD-JT30...
Hitachi PJ-TX10 alligment
i have one of these projectors found on setting it up that the projector must be square on with the screen, the pjtx10 doesn't have ant "wedge type" setting like sony does. if this doesn't fix problem there is some thing not aligned in the lense
Mar 04, 2008 | Hitachi PJ-TX10 Multimedia Projector
Blurred image from sony home theatre projector
Unfortunately an expensive repair or total replacement are probably your only real options. Electronically the projector is fine but your problem lies in the physical optics part of it. Either part of the lense assembly or the refraction array is likely damaged or at least very dirty. I wouldn't suggest trying to clean it yourself as this is a 3 LCD projector and all 3 must align perfectly after cleaning or you'll end up with seperated colors. It could also be one of the LCD's is damaged but from your description I don't think so.
I have a client that had the exact same issue with a different VPL model and it was cheaper to go out and buy a new projector than to fix it.
Jan 18, 2008 | Sony VPL HS10 Multimedia Projector
Why is my projection dark and muddy compared to the brightness on my computer screen?
John here, customer advocate at Dell headquarters. If you can nvigate to the On Screen Display Menu, you should see an "all images" section on the main menu. There you will find brightness, contrast, color temp, white intensity, and gamma controls. You should be able to make adjustments from that menu to sharpen and brighten the image.
May 03, 2007 | Dell 1100MP DLP Projector Multimedia...
91 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
