Question about Canon ZR70MC Mini DV Digital Camcorder
Can't record stays on pause and has a symbol I do not understand
I am trying to record and the recorder is stuck on pause. I have no idea what to do. There is also a symol with a line through it please help!
    Sergeant:
    Champion:
  • 370 Answers
The cassette is the problem ...replace it ...
Posted on Mar 06, 2009
Stuck in standby
You probably need to press play or record or pause release in addition to what you have been doing. When I try to record I sometimes then have to press record or the pause again as it is in a holding setting to help you set the sound level before recording.
If it is not this fix the deck probably has mechanical problems due to age. I have had Sony decks which worked fine sit in storage for a time then never work again - I don't know why either.
Jan 13, 2014 | Sony MDS-JE330 Mini Disc Player
How do I pause when recording?
I understand that you wish to Pause and Continue recording to record several scenes in a single file. Unfortunately, HDD Camcorders(regardless of manufacturer) do not have the option to pause and record in a single file. Once you press STOP, it will save the current file and When you press the Record again, it will start record as a new file. This is because of the characteristics of the HDD media. If you wish to have the video as a single file, please use a video editing software to combine the videos.
Thanks for understanding. Please let me know if you require any clarifications.
Jul 06, 2011 | JVC GZ-MG130U Camcorder
I have an emerson euphoria am/fm stereo radio/cd player/cassette recorder. i want to record on cassette. there are 6 buttons with symbols on them. what are they and which do i use to record
the standard tape symbols are as follows.
triangle on side pointing right - play
filled dot - record these need to be pressed at the same time.
while recording
II symbol is to pause
square is stop.
double arrows left is rewind
doubble arrows right is fast forward.
arrow up with a base is eject.
Nov 13, 2009 | Emerson PD6810 CD Boombox
D1lee@airmail.net DRC8320N, records with intermittent pauses
just a long shot here but have you tried giving it's case a thump it could have a dry joint....
Sep 14, 2009 | RCA DRC8300N DVD Recorder/VCR
Hi can i record on my pioneer pdr 609 cd without using the remote control,as ive purchased a unit with out one and cant get it to record, thanks
Hi John
You should be able to record without the remote control; make sure you have a blank disc in place, then press the 'RECORD' button on the front; it should go into recording standby mode. When you want to start recording, press the button below the REC BALANCE buttons (the play/pause button, marked with a triangle and a II symbol) and this should get you going.
Try it and get back to me if not.
Hope it works!
Kev
Jul 25, 2009 | Pioneer PD-R609 CD Recorder
How can i pause in middle of taking a video
Perhaps I'm not understanding your question, but if you mean simply pause while taping someone or something, you hit the record button again. This will pause, and then to restart you hit record again.
Apr 27, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Telephone recording won't work
You need to have a telephone record adapter plugged into the back of the 3750. Then you press and hold the Tel Rec button until it begins recording.
Also check to see if the 'Vox' or 'VA' switch is on (voice activation). This will cause the machine to pause if the volume is too low.
Jan 15, 2009 | Dictaphone 3750 Desktop Cassette...
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
Canon zr40 stuck in pause mode
Remove the battery.   Wait 10 seconds.  Put it back in and see if that resets it.
Sep 09, 2008 | Canon ZR40 Mini DV Digital Camcorder
Progressive feature
Hi! I had the same problem. Press the pause button on the RECORDER for 5 seconds and the progressive light will go off. Not the remote, the recorder.
Jul 19, 2007 | Sony RDR-VX530 DVD Recorder/VCR
Canon ZR70MC Mini DV Digital Camcorder Logo
97 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Chris Phillips
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
