Question about Sharp Microwave Ovens
No numbered touch pad for use setting clock
Sharp Half-Pint #R120DK doesn't have the typical numbered touch pad to use when setting the clock. Sharp doesn't make the manual available to consult online. How do you set the clock on this model?
  • mlat5151 Mar 08, 2009
    Here is exactly how to do it:
    Press CLOCK/TIMER to make 0 appear in window.
    Use 1 MIN button or 10 MIN button to set desired hour.
    Press CLOCK/TIMER once to lock in hour and make 00 minutes appear.
    Use 1 MIN button and 10 MIN button to set correct minute.
    Press
    Press CLOCK/TIMER once to lock in time.
  • Sharp Master
  • 9,098 Answers
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Posted on Mar 06, 2009
  • William Miller
    William Miller Mar 10, 2009
    Very good.
    We're
    New Friend:
Clock button + minute button + minuteS button + clock button + seconds button + minute button Sets the four positions of time.
Posted on Mar 27, 2016
I cannot reset clock
Touch Timer/Clock pad and number 2 pad.
Enter the correct time of day by touching the numbers in sequence.
Touch Timer/Clock pad again.
Aug 15, 2015 | Sharp Carousel R530EST Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Sharp Microwave on "Lock" and
    The Child Lock prevents unwanted oven operation such as by small children. The oven can be set so that the control panel is deactivated or locked. To set, touch CLOCK, the number 1 pad and then touch the START pad and hold for 3 seconds. Should a pad be touched, will appear in the display. To cancel, touch CLOCK, the number 1 and STOP/CLEAR pads
    Mar 08, 2011 | Microwave Ovens
    How to set clock?
    You can set the clock to a 12 or 24 hour system.
    For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
    For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
    Mar 05, 2011 | Emerson MW8107WA Microwave Oven
    I REQUIRE A WAVEGUIDE COVER REPLACEMENT SHARP
    Here's a link to the parts listing at searspartsdirect.com:
    http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R120DK/0958/0123245?searchedModel=r-120d&blt=
    The list also includes helpful schematic diagrams that you can print for future troubleshooting.
    if you need further assistance, please post back and let me know. I hope this helps you.
    Nov 03, 2010 | Sharp R-120D Microwave Oven
    How to set clock on asda microwave, p80d20al t5
    1. Touch CLOCK pad.
    2. Touch CANCEL pad.
    3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
    4. Touch CLOCK pad again.
    Aug 31, 2010 | Microwave Ovens
    How to set the clock on my sharp carousel microwave
    Touch STOP/CLEAR pad.
    Touch TIMER/CLOCK pad.
    Enter the correct time of day by touching the numbers above in sequence.
    (for example: for 12:30, touch 1 2 3 0)
    Touch TIMER/CLOCK pad again.
    Sep 25, 2009 | Sharp Microwave Ovens
    The clock works & counts down but the microwave won't heat
    • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
    • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
    Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
    Aug 03, 2009 | Sharp R-1460 Microwave Oven
    How to set the time, and can i download a usermanual anywhere? Thanks
    Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again...should set.
    I have not seen a manual on-line for your model...ut htere are many others...perhaps browsing thru a few might help you. If not...try going into a store and looking for that model...the management might copy if for you...I would. :-)
    Apr 24, 2009 | Microwave Ovens
    Dont know how to get it working
    You may need to open and close the door first.
    Press CLOCK > 1 > 2 > 3 > CLOCK.
    Let us know if this doesn;t work. You may have a bad door switch or mount.
    Nov 30, 2008 | Microwave Ovens
    Microwave Ovens Logo
    422 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
