Question about EliteGroup MB ECS A770M-A 770 SB600 AM2+ RTL Motherboard
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything and rebuilt it and ever tryed changing ddr and cpu allso still nuthing i even flashed the bios and still it wont boot please help
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Did you replace the hard drive? The hard drive is what holds the master boot record & Operating system. Without these your system will not boot.
  • Matt H
    Matt H May 11, 2010
    If the Hard Disk Drive (HDD) is an IDE HDD (ribbon cable that's flat), you may have plugged the HDD into the wrong spot or backwards. Although most motherboards/HDDs have notches to prevent you from doing this, it is possible.
    It is also important to note that static electricity is dangerous for a computer. If you can feel a shock, you've fried it. Not feeling a shock does not always mean it has not been damaged from static electricity. Here are some things I need to know:
    • When you boot the PC up, does the HDD spin at all (feel it from the sides)?
    • If it does, is there a clicking sound that's heard from the HDD (one or so clicks could be fine, but clicking over and over is bad)?
    • When you boot the PC, can you enter the BIOS?
    • If you can, does it detect the HDD exists?
    • I asked this above, but is the HDD IDE or SATA? IDE will be a long ribbon cable with a black or grey ended rectangle plug-in and SATA will look like a skinny little cable with a plug end that always has a small notch making it look like an "L".
    • If it is IDE, do you have the cable plugged in so the BLUE end is attached to the motherboard and the black end is plugged into the HDD? The blue ends signifies the end that should attach to the motherboard. The black end means MASTER (the primary drive) and the grey means SLAVE (the secondary drive).
    These are all questions that need answered as the original post does not give enough information. Thanks!
  • 43 Answers
Its better to format if again. But, if you have some important files there, Serve that drive as secondary slave to other computer have OS already and get you files.
Posted on Mar 12, 2009
  • 530 Answers
Hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Boot order: Traditionally, a computer is set to boot first from the floppy drive, and then from the main hard drive (Drive C). This means that the computer will check the floppy drive first for boot files. If there is no disk in the floppy drive, the computer will then go to the hard drive to look for boot files. That is why if you leave a non-bootable floppy disk in the drive and try to boot up, you'll get an error message such as "NTLDR is missing. Press any key to restart." or "Non-system disk or disk error." This can be changed to pretty much any order, including CD and DVD drives. It is useful when installing Windows on a new or just-formatted computer to set the computer to boot first from a CD-ROM drive, and then insert the Windows installation CD-ROM into that drive. This saves you from having to use boot floppies that might or might not come with the Windows CD-ROM. Good luck.
Posted on Mar 06, 2009
  • Joseph Baculan
    Joseph Baculan Mar 06, 2009
    hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Power shuts down after booting up???
Could be a GPU issue. Could be a software issue. Remove the hard drive, re boot. The system should ask for a bootable device. If it does, the GPU is OK and you possibly have a hard drive error.
Nov 01, 2013 | Computers & Internet
Hi, i have an eee laptop!! and some of the keyboards are not working!!! is there any key that can subtitute the fn key?
Hi wincel03_dar ,
I see that you are having issue booting into your Windows, I can help you with your concern. You mentioned that you get a black screen with a blinking cursor on the upper left, this means that either your Hard drive is not detected by the motherboard or Windows is not found, see steps below.
  • Turn your Laptop ON then keep on tapping F8, you should see a screen windows advance options menu, hight light and select Last Known Boot Configuration then press Enter
  • The Laptop will restart, see if it will boot into Windosws
  • From shut down turn your Laptop on again then keep on tapping F12 this will give you a Boot Menu Screen.
  • Once you have the boot menu screen Select ATA HDD it should be the first on the list if it is not located then the Hard drive isn't really detected.
  • After selecting the ATA HDD press Enter this should boot into the Hard drive, if still it does not boot and it gives you the same black screen with a blinking cursor then you can try reseating your Hard drive from the system.
  • Reseating meaning Remove it then wait a couple of seconds then put it back in properly then try turning the machine on again.
If still he issue is the same and you get a Blinking Cursor then it can be two thing either you Hard drive has gone bad or your motherboard could not detect your Hard drive.
To find out you can try and use your Hard drive on a different Laptop if the data from your Hard drive works on a different Laptop then your Hard drive is OK and that the problem is your Motherboard not be able to detect your Hard drive and need replacing.
I ope that this will be able to help you with your concern,
Thank you choosing Fixya.
mvincentc
Apr 18, 2011 | ASUS Eee 4G Notebook
My laptop dont read hard disk drive
Okay, shut down your laptop, turn it up side down, remove laptop battery, remove Cd drive by first unscrewing the CD drive's screw before removing/detaching the Cd drive from the computer.
Turn on your computer without the Cd/drive, allow computer to boot, after a while, shut down computer, fix in back the CD drive and turn the system back on.
By now the system should read the CD drive. If it does not, then I'm afraid some this is wrong with the Drive, but I'm sure it should work.
Take care.
Apr 14, 2010 | HP Compaq Presario C500t Notebook
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
Dell deminsion 3000, fans run, hard drive light on, no boot up.
Very possibly you can unhook the hard drive and cd dvd drivers then boot system see if it goes to post try and get to setup if that does not work then you system board problems or cpu problems.
Mar 16, 2009 | Dell Dimension 3000 PC Desktop
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything...
first thing to do is unplug the machine, hold the power button in for 20 sec. after unplugging it, then remove the disc battery you should see in the mother board, keep it out for 60 sec. then replace it plug it back in nad reboot it. lets start from there and get back with me and please don't forget to rank this solution and if I can be of any other help let me know. Have a wonderfull day and thank you for using fixya.com
Mar 05, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Power steering
Make sure the fluid level is OK, if reservoir MT ad, with out the cap till air comes out and fluid gets in to system, turn the steering right to left wile You add fluid with cap off, till fluid is not longer going down and reservoir inside gets quiet, when fluid level is OK, put cap back and try it, if system did not recovered normality and loud noise comes from the pump, pump needs replacing, if steering is steel hard, no noise comes from pump, look a steering box or steering arms, if truck has Rakenpinon, look for broken boots, pit man arm
Jan 22, 2009 | 2001 Dodge Ram 2500 Truck
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Computer does not boot up completely -shuts down by itself
for xp there was a update called service pack 3 witch caused alot of compaq to just boot the shut off this seems to be ur problem although i am not sure of ur pc's brand hope this helps
Here to Help
Shaun
Nov 24, 2008 | Computers & Internet
Acer quit working
Well, the 1st thing to check is boot into safe mode (F8 at boot) and see if you can get to the desktop.
If you can, run system restore and then see if you can boot to normal mode.
If it shuts down, boot to the system BIOS, and see if the system will continue to run, if it does, then your issue is most likely a operating system problem or a hard drive problem causing an OS problem.
If the system doesn't shut down in BIOS, next is try to boot to a CD. You may have to remove the Hard Drive to exclude it from the issue. If the system boots to a CD and will continue to run, then we are pretty sure the HDD/OS is the issue.
Next would be trying to run diagnostics on the hard drive, if they fail, replace the drive. If they pass, reinstall WIndows.
Jul 11, 2008 | Acer Aspire 5315 Notebook
EliteGroup MB ECS A770M-A 770 SB600 AM2+ RTL Motherboard Logo
136 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
