Question about Garden
My homelite 240 stopped oiling the chain? - Garden
  • dtate7289 Mar 06, 2009
    Great thanks Good job.
Recently had same problem with our Poulan. We ended up replacing the the oil pump because the gears were worn. Not saying this is your problem but is a possibility.
Posted on Mar 06, 2009
What is the oil to gas ratio for homelite model 360?
I cannot find the full details for the model 360 chain saw but a typical Homelite chain saw uses the 50/1 gas/oil ratio.
1 gallon (US) 2,6 oz
1 litre 20 cc (20 ml)
If you want to download the user manual for your chain saw then please check the full model number . for example UTxxx and select this in the Homelite site.
Product Owner Manuals
Aug 21, 2014 | Homelite Garden
What kind of oil goes in the oil fill?
Use standard bar and chain oil...it is for the chain
Jan 06, 2012 | Homelite Garden
Does a homelite chain saw have a crank case youn put oil in homelite xl
Hi, it needs a two cycle mix at a ratio of 25 to 1 in the fuel tank and bar and chain oil in the oil tank. Hope this helps, regards Phil.
May 31, 2011 | Homelite Garden
Where can I get a replacement air filter for a Homelite 240 chain saw? No place/site seems to have them.
Jacks Small Engines claims to stock them and he does an on line business. If you are still not able to obtain an air filter, I have made air filters using Scotch Brite of the correct thickness. It allows sufficient air through and the oil spray back through the carb assists in dust trapping. Good luck and please rate this response.
May 19, 2011 | Homelite Garden
It stopped oiling the chain and putting air bubbles back in to the oil tank . the model 240 homelite UT-10621
The first thing is to clean the bar, oil ports, then the main port in the case, blockage is the main cause. When the bar area is clean,
Take a stright pin and try and clean out the port as much as you can,then if you have a shop vac that has a attachment that goes to a smaller end, such on the port and get any lose dust out.
If this does not work the pump could need to be rebuilt.
Feb 15, 2010 | Homelite Garden
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
Homelite ut-10942-a chain stops under load
Could be the internals of the clutch have been heavily oiled--wash out with carburetor cleaner from an auto parts store. The internals of the clutch expand to the internal rim of the clutch housing when things rev up. Oil blocks the necessary friction needed between those parts. Make sure the chain sprocket is attached firmly to the clutch housing.
Jun 30, 2009 | Garden
Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Jun 29, 2009 | Homelite ZR10926 16 Chain Saw
Looking for a Homelite 16'' chain saw bar part number PT1637144
You might try psep.biz for the bar. They list some replacement bars that should fit the model number 240 that you listed. If you don't find what you need let me know and I will try another site.
Mar 15, 2009 | Homelite Garden
Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Dec 29, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
546 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
