Question about Microsoft Xbox 360 Console
To play this disk put it in an X-Box 360 console??? Nice message after I replaced the disk drive. I bought a new driver made for the 360 and it still only shows disks for DVD ??
    Problem Solver:
  • 19 Answers
The dvd drive and the motherboard have a key that must match each other. The xbox 360 dvd drives are not plug-and-play. You must first extract the key from the original drive and spoof firmware to make the new drive match the key on the motherboard. There is an easy way though.... just take the pcb board out of the old drive and stick it into the new one, then everything should work fine withough messing with the firmware. If you need more help, just ask on our xbox 360 dvd drive repair forum
Posted on Mar 06, 2009
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Xbox 360 Pro : To Play This Disk Error
Unfortunately , a new xbox360 game cant be played in a normal xbox (not xbox 360)
The problem is that the new xbox is way different on the inside than the original xbox is. Because it is way more powerful, you can put an old xbox game into a 360, and it will work fine (most of the time), but if you try the reverse there is no way to make it work.
May 13, 2009 | Microsoft Xbox 360 Pro System Console
Xbox 360 thinks game is dvd
your laser is going out or something, or its dirty. mine was doing this to me. eventually it would not see the disc at all and kept saying open tray. i bought a philips laser lens cleaner for around 8 bucks and its helped me out so far. from what i've read though, this is only a temporary solution and will require service eventually.
Jan 14, 2009 | Microsoft Xbox 360 Console
Xbox360 wont play games only dvd
You can't just replace the drive with a working drive on the xbox 360. the drive is married to the mainboard with a special key. If you replacing the drive with a drive that's the same brand/model them you can take the logic board from the old drive and put it in the replacement drive. otherwise you will have to extract the key from your old drive and patch in the new drive. not an easy task.
Jan 08, 2009 | Microsoft Xbox 360 Console
New XBox 360 putting scratch in games
the problem is the disc drive.
you have to open it up and put some stick foam " like a sticky strip of foam, insulator : on top of the drive .
the problem is that the disc touches the laser assembly while turning cheating a ring on the disc.
i can fix your games as well as the disc drive if you feel like is to complicated.
Jan 02, 2009 | Microsoft Xbox 360 Console
My xbox 360 keeps puting scratches on my games
check to see if anything is obscuring the disc tray on opening and closing.
If there isnt check the disc make sure its smooth and flat no bumps and not bent
if there is noises like grinding when playing it may be a part inside causing this
i suggest calling xbox because i dought u want to risk doing this to other games.
please rate. thank you
Dec 17, 2008 | Microsoft Xbox 360 Console
Games won't work
the problem lies within your hard drive. first thing youll have to do is perform a matenince on the hard drive. to perform this you must go into settings, memory, select your hard drive, then enter the following code... LB LB X X RB RB... it will say are you sure you want tot perform this. select yes... when this is done and the games still dont work, you'll have to format your hard drive. and after youve done that and they still dont work, you'll then have to buy a new hard drive
Oct 05, 2008 | Microsoft Xbox 360 Console
Game will not play
your drive lens is going out and need to be replaced by either gettin a new drive or replacing the eye itself. good luck
Jul 28, 2008 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
Nov 07, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
98 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
