Question about Sony VAIO VGC-RB42G PC Desktop
Computer wont start up. Blinking green light in the back of tower
My computer wont start up and it seems there is a blinking green light in the back whenever i connect it to my power supply.
I read that when Vaio's do this, its usually the power supply or the motherboard.
So which one is it?
and how do i un-hook all the stuff to my mother board to test for power problems.
  • 1 more comment
  • aacrod Mar 07, 2009
    I have the EXACT same problem. This is the first time I've had this problem. I do know that my power went out and when it returned, I could not turn on my computer. Any suggestions out there?
  • mima2116 May 11, 2010
    frosty 17 thank u so much this really works on my husband computer he was so worry about loosing his pc
    thanks god for people like u
  • Timothy Bright May 11, 2010
    Chances are its a power supply issue. Only way to test this is trying a new power supply. Did you recently just upgrade RAM or the motherboard on your computer? And what year was the computer made in? Older motherboards sometimes cannot handle more RAM then they were designed for.
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Posted on May 03, 2009
  • wmcgreg
    wmcgreg Aug 02, 2012
    Frosty17 u r AWESOME!!
  • Joshua Sndheimer
    Joshua Sndheimer Mar 14, 2015
    I understand that this thread is quite old but I wanted to tell you how much I appreciate you posting this on the internet as you saved me from having to buy a brand new motherboard or power supply thank you so very much and you're awesome
I had the same problem as above and all u do is unplug it as described in the above comment. Make sure power cord is in it and then unplug it . plug back in and bam it works. thx
Posted on Nov 04, 2009
My computer does the same thing, no power what so ever too it, but a green light on the back of the computer where the power supply is just keeping blinking and making a clicking noise on every blink....
i tryed unhooking the rectangle plug in from the inside and plugging it back in while the computer was plugged into the wall.. but nothing.. when i have the wire from the inside unlpugged the green light is steady.. but when plugged back in it starts blinking again... ahhhh,,,
Posted on Dec 29, 2009
It's actually a setting in the CMOS. There is an option that says something like "On Power Failure" then there are 3 options to choose from. "Stay Off", "Power On", and I forgot the other one.
What I did was powered it up with a different Power Supply,went into the CMOS and chose "Power On",Turned off computer and plugged the old supply back in and it works.
Hope this prevents this from happening to you guys again.
Daniel Valentine
PC Guru,and owner of PC Paramedics 302
Posted on Dec 25, 2009
    Habit-Forming:
  • 152 Answers
Sony has a excellent support website (link included) If you are getting a green light and you can open your CD-ROM drive or floppy drive lights up when you turn power on then it is probably not your power supply. This don't mean *********** board is bad. Larry
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGCRB42G&LOC=3
Posted on Mar 06, 2009
I have an HP and my son accidentally kicked it. Disconnecting the power supply worked for me too!
Posted on May 20, 2012
The light on my computer tower is blinking green on the back
If it's blinking green than most likely the power supply needs to be changed
Aug 13, 2014 | Computers & Internet
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
I have a Compaq Presario SR2010NX that will not boot. When I plug in the power cable, a green light blinks at the back of the tower on the power supply. I was given the desktop in mint condition, which...
your power supply is bad. the blinking light means there is a failed component in the power supply. replace the power supply and you will be good to go. around 60 dollars at any computer place. please rate me thank you.
Jan 04, 2011 | HP Compaq Presario SR2010NX PC Desktop
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
Turn off the computer by pressing on the power button on the system tower for 10 seconds.
Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
Reconnect the power cord and then power on the computer to see if the issue is resolved.
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell XPS 200 PC Desktop
SONY TOWER GREEN LIGHT BLINK
Try to take out the battery on the MoBo. It's a button battery that says CR2032. Let it sit for 2 minutes, put the battery back in and power it up.
Aug 24, 2009 | Sony VAIO VGC-RB42G PC Desktop
Sony Tower green light blinking
Could be a bad power supply or a bad motherboard.
Mar 21, 2009 | Sony VAIO VGC-RB42G PC Desktop
Moniter won't turn on/power light blinks green
Yeah, I called Dell yesterday, and they said it was a problem that I could not fix myself. Whether that's true or not, I don't know, but my monitor was still under warranty, so they shipped me a replacement right away. I already got it this morning.
FYI: Their monitors carry a three year warranty.
Oct 28, 2008 | Dell E176FP 17" LCD Monitor
Green light blinking on back of my system unit but there is no power
I had this problem and i tried everything to make it work. Now all i do is put a hairdryer at the back whilst the computer is plugged in until the light stops flashing then switch on as normal. I also noticed that when the air is warm i do not have to use the hairdryer hopes this helps.
Aug 31, 2008 | Computers & Internet
Sony VAIO VGC-RB42G PC Desktop Logo
6,720 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
