Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
We have 2 sensors. 1 has a green light and the other has no light
We have 2 sensors. 1 has a green light and the other one doesn't have a light. The garage door would go down 1/4 of the way but vome back up. Then the light connected to it blinks 10 times. It'll only go all the way down if you hold it down until it shuts.
  • jason May 11, 2010
    have you tried readjusting the tension adjustment ?
    or have you looked to see what might be causing it to have strain ?
  • 118 Answers
Your safety eyes are out of ajustment. Make sure that the eyes are pointing directly at each other. A light will come on on each eye when they are properly aligned. The only other thing that could be wrong is that one of the safety eyes could be bad, and the only thing you can do is replace the eyes. 99% of the time the problem is an alignment issue. By holding down the wall button, you are overriding the safety eyes.
Posted on Mar 06, 2009
Sears craftsman 1/2 hp. Door goes up with remote, but when button pushed to go down the light flashes and door doesn't move. If you push the wall mounted switch, the door goes down like normal. Works...
Check the sensors in the doorway. They should both have a small light that is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
During a garage remodel, my Sears automatic garage motor was unplugged and the wire going from the motor to the push button on the wall had to be cut and spliced back together. Door wouldn't go down on...
Make sure the solid white wire from each door sensor is attached to terminal #2 and the white wire with the black tracer is attached to terminal #3.
The solid white wire from the wall control goes to terminal #2 and the white wire with the red tracer goes to terminal #1.
If the green light in the wall control is blinking press and hold the lock button for 3 seconds.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door will not close. The door gets close to the ground, then starts back up again and when it gets to the top the lights flash.
Just got off the phone from one of the rep's of Chamberlain...Go to the sensor that is blinking(it should be the one with the green light) loosen the sensor until the light goes out, then tighten it back up until the light come back on, and push the garage door opener. it should reset the unit.
Oct 09, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Liftmaster 1/2 horse Model HBW0777 acts like the safety sensor is stuck (door won't continue down - re-opens when you let go of the wall button. I can close it with the wall button but I need to hold it...
If the main light flashes 10 times when the door reverses it is a door sensor problem. Look closely at the green lights to make sure one isn't flickering ever so slightly. Tweak them a bit.
Mar 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Both lights on our garage door sensors are green (not blinking), but the door will not close with the remote or button in the garage. It does close if you force it by holding down the button in the garage....
If the main light flashes 10 times when the door starts to close and then reverses it is a door sensor problem. Look very closely at the lights on the sensors. If one of them is flickering ever so slightly it will give you the problem you have.
If the main light is not flashing then you need to increase the down force which is near where all those white wires go. A 1/4 turn should do it.
Nov 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do we reset our Craftsman 1/2 HP Part# 41A4315 - 7A garage door opener? When you press the button is goes down a little ways and then back up. The little green sensor lights will not come on either,...
If the lights in the door sensors do not light you have either a bad logic board or bad wiring to the sensors. Replacing the logic board is usually the cure.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door sensors out of alignment
The lights are suppost to be yellow (power to photo eyes) and green (lined up).
 1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
  1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
  2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door
Are the sensor lights located on each side of the garage door opening? Have you checked to see if they are in alignment with each other? Also check to see that any wire from the sensors are disconnected on the motor or at the sensor itself. Good Luck! Countrycurt0
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage sensor problem
The colour on the sensors doesn't change.
One is orange constantly and the other is green when detecting a signal from the orange sensor.
If the green is flickering, they are not adjusted correctly.Move the green sensor until you get a good solid green. Holding the wall pad button down, just bypasses the sensors.
Try adjusting only the sensors so that they are solid.
In addition, check the little yellow light on the back of the machine and count the flashes.
The number of flashes will tell you what the error is in your manual.
Jun 18, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
239 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
