EN Control buttons separating from control mounting bracket. Affected Countries CA, US Affected Appliances HPCN36NS/01, HPCB36NS/01, HPCN48NS/01, HPCB48NS/01 Fault description / Customers complaint / Diagnostic Codes Diagnostic Codes (DC) The following table contains the diagnostic codes, which most commonly occur in connection with the mentioned fault description. Depending on the actual information from the customer, other diagnostic codes are possible. DC Fault description of the customer 160100X45000 Mechanical damage / Holder Root cause On some Thermador Professional hoods with FD 9407 to 9611, the control buttons may separate from the control mounting bracket due to insufficient adhesive between the control mounting bracket and the inside of the hood canopy. Solution Beginning with FD 9612, wider tape was implemented in production. For units built prior to that time, service kit 12022532 is available. The new repair kit includes the control-mounting bracket with wider tape affixed to it, and four screws. The tape will provide more surface coverage to improve the support of the mounting bracket.
You should be able to use parentheses in the same order in which you would write the arithmetic expression. For example, 4*(3.5-1.5)= should give you 8. Without the parentheses, this would 12.5.
Essentially, the left parenthesis comes immediately after an arithmetic operator, and the right parenthesis must close the parenthetical expression right after a number, and an operator must follow the right parenthesis.
What are you trying to do? If you are just trying to solve a problem that is in your math book, then parentheses will act just as brackets, for example:
[2(1+1)] = 4
(2(1+1)) = 4
These statements are exactly the same to your calculator. Just make sure to complete all of the parenthesis. If you are trying to do something else, from reading the calculator manual I was not able to find support for brackets.
Use the parenthesis above the 8 and 9 keys. Don't use the curly braces on those shifted keys (those are for lists) nor the square brackets on the multiply and subract keys (those are for arrays).
For negative numbers (not just exponents), use the +()- key to the right of the decimal point. For brackets, use the parenthesis keys above the 8 and 9 keys. You can nest more than one set if needed.
Type "YourPartNo" into the "Search for your parts by Part #:" window, then click search.
Click the 111182-01 - USE REPLACEMENT PART # 111304-01 "View Part" link.
Part #:111304-01 Price: $15.00Description: CHAINSAW BRACKET 747 - Click the "ADD TO CART" link.
Remington has stopped all production and most replacement parts are NLA. Look toward Heaven and utter Thank You. Lou I would waste no time ordering this part. 1 (800) 475-5660.
