What is error pc
When turned on and after warm up the information panel reads PC. What does this error mean?
  • Anonymous May 01, 2009
    The copier stopped mid-copying job and said P.C.  I have no idea how to fix it.
  • Office Equip... Master
  • 1,297 Answers
The PhotoConductor unit.You need change the OPC drum or a new cartridge.
Posted on Aug 05, 2009
What does it mean if the car runs good until it warms up then loses power
Fuel supply, or sensors providing information to the ECU. Take by your favorite auto parts shop, ask nicely to read your error codes. That will probably give you an idea. I found with my 20 yr old car that corrosion on sensor connections caused error codes so clean and scrape to bright metal. fixed the errors and the bad behaviors caused by them.
Apr 10, 2015 | 1993 Jeep Grand Cherokee
I have an emachines ET1331G-07w.....I cannot boot up windows. My screen is black and reads.......Reads......Reboot and select proper boot device......Tried alot and have no solution?? TY
Usually this error message means the computer doesn't "see" your hard drive. Remove the power cord then remove the side panel of the computer case. Check that the hard drive power cable and data cable are both plugged in firmly to the hard drive and to the motherboard. Plug the power cord back in and try booting up.
Nov 19, 2013 | E-Machines eMachines Desktop PC
Error beeps
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
TWO BEEPS CAN MEAN MEMORY OR MOTHERBOARD.
READ FOR MOORE INFORMATION.
Jul 22, 2013 | Sony VAIO Computers & Internet
I have a TE 2000 casio till, it is printing Error 180 on the receipt roll & on the display it will state the relevant header ie reg, x, y, calc but will have flashing dotted lines under the heading....
This is an RS-232 error. It means the machine is trying to communicate with another device. If you have a PC or other device connected to the port, make sure you do not power it up with the cash register turned on or you will often receive this error. If the error just happens during normal use with nothing plugged into the port, then it has a fault. Some models were affected by this. It will often lock the register up until turned off and left to cool. A dealer can repair this problem. ------------------------------------------------------
If anyone needs more information, the Casio TE-2000 manuals are here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Aug 25, 2011 | Casio Parts Cash Register PC Desktop
A DISK READ ERROR HAS OCCURED PRESS CTRL+ALT+DELETE TO RESTART
This can mean a couple things... Your PC might have gotten corrupted by a virus, or the hard drive is going bad. Try pressing "F8" key upon boot up and see if you can get into the computer in safe mode.
If you can then go to "My Computer" and then right click on the c drive and select "properties". You will then go to the "Tools" tab and run an error check on the drive. After that you will want to try scanning your computer for any possible infections.
If you can not get the PC into safe mode then you will need to reformat the drive and reload your PC. But if you have information on the drive that you need. Your best bet then is to go out and get and external cabinet for your hard drive and a new hard drive. Put the new drive in your PC and the old drive in the external for later. Reload the PC and then copy the information off the old drive onto your new hard drive.
Best of luck...
Nov 22, 2010 | Computers & Internet
My computer fell and when I turned it back on it's saying check cable connection..! PXE-E63: Error while initializing the NIC pxe-m0f:Exiting Intel pxe rom no bootable device
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
Nov 09, 2009 | Acer Aspire One PC Notebook
Error msg.
hi: first at all what program are you try to load? do you try to do a new install of os ?please be a litter more specific, but usually that error is due a application that is not stared correct, , so for give you a better solution please post a litter bit more of information about your problem. best regards italocub.
Jun 12, 2009 | E-Machines eMachines Desktop PC
Have aproblem getting on the internet. problem with network adapt
First - try step one- If that doesn't work, try step two.
Many virus scanners prevent programs from accessing the internet. Please go to download.avg.com This user manual will show you what settings you you can put your new software at to access the internet.
2. If that doesn't work- restore the system to the day before you added the software
Mar 27, 2009 | Gateway GM5664 Desktop PC
Error message: The instruction @ 0x1004628 reference memory
Hi there go to microsoft.com and search error codes and it will give you all of the information about the error and it's meaning
Mar 17, 2009 | E-Machines eMachines Desktop PC
Chefmate HB-215
My book doesn't have an error message E-07, only E-01 and E-02. Both error messages will beep.
E-01 means baking area too hot. To reset open lid and remove bread case to cool. After panel message disappears replace bread case and press start.
E-02 means baking area too cold. Unplug unit and allow it and the baking area to warm. Then try again.
Hope this helps.
Oct 12, 2008 | Chefmate TR 7000 Bread Maker
53 people viewed this question
jasbo
jasbo
