Question about Samsung Instinct Cell Phone
Download Mode Every time I turn on my phone it goes to this download mode screen like this. DOWNLOAD MODE Mode : Emergency Port : USB Please help me
  • jennifersief May 22, 2009
    I was trying to turn off the phone and then it just went into Download Mode Target name:SPH-M800.What does this mean? Is the phone broke?
  • Anonymous Mar 15, 2014
    phone was turned off and then went into "USB download mode" Nothing functions now.
  • 89 Answers
Let your phone die, and then charge it up and see if it happens again. If it does, try to have it repaired or exchanged.
Posted on Apr 07, 2009
4 Suggested Answers
bunnydawg
  • 5158 Answers
SOURCE: my rant is stuck on download mode screen says mode
remove the battery for about five minutes and see if that helps.
Posted on Jun 09, 2009
nasirahmed
  • 282 Answers
SOURCE: my samsung sph-a900 phone now
Clean the phone usb connector below.
Posted on May 17, 2008
  • 165 Answers
SOURCE: dropped phone (Samsung SPH-M540), may
Try & press the reset button. It is near or under the battery. You night need to use the end of a paperclip. If that fails see your provider.
Posted on Dec 05, 2010
Dropped phone (Samsung SPH-M540), may have gotten wet. Screen will only show Download Mode --Mode: Emergency Port: USB
Dec 05, 2010 | Cell Phones
Sch-u450 got wet and is now stuck in download mode. screen shows, Mode : Emergency Port : USB cannot turn off, does not accept any key entrys
This is a device issue due to water damage. You will need to contact your service provider for replacement options!
Mar 10, 2010 | Samsung SCH-U450 Cell Phone
I turn on my phone it goes to a screen saying Emergency Download
Wait does it say emergency mode only? If so this has happened to me many times on this phone.
Turn off the phone and remove the battery. In there will be you should see the SIM card. Pull out the SIM and put it back in. Put back the battery and turn on your phone.
For some reason on these phones the SIM card gets dislodged. When it does the phone won't work because the SIM card is what makes the phone your number etc. All cell phones, that have no service otherwise will be able to call 911. Apparently it is a law, so that is why your phone is on emergency mode. Without the SIM card the phone is a phone without service and will therefore only work in emergency mode.
I hope this is what you meant.
Aug 13, 2009 | LG Vu CU920 Cellular Phone
My phone is stuck on an "emergency download mode" screen.
Did you ever find a solution to this problem!? Mine has the same screen...
Jun 16, 2009 | Pantech Matrix Cell Phone
I'm stuck on the yellow screen thats says "refreshing"
This could be a software or a hardware fault. If you recently changed the firmware or made other modifications to the file-system using EFS Explorer (or similar software), it may well be software related.
If you think the problem may be software related, try using Emergency Download mode to reflash your phone.
Possible faults to check with the hardware include:
  • The battery is empty, damaged or worn out. Try taking the battery out and connection your phone using the USB cable only.
  • The contacts of the battery are damaged or the battery has leaked.
  • The screen may be damaged and will not display a picture - check if the lower buttons light up when the End Call (Red) key is pressed.
In the case of a hardware fault or if you are unsure, contact the store from where your purchased your phone on for advice on the best action to take.
Emergency Download Mode __________________________________________ What is Emergency Download Mode? Emergency Download Mode allows you to connect your phone to your computer and use flashing tools (e.g. LGDMP) to restore or change your firmware.
_________________________________________________________
How do I access Emergency Download Mode?
  1. Make sure your phone is off.
  2. Hold down the Green (Call) + C (Delete) + Red (End Call) + Image Stabiliser (Lock) buttons
  3. Your phone should turn on and go straight to a screen saying 'Emergency Download' without first showing the usual LG Logo.
  4. You can now connect your phone using the USB cable and use Flashing tools to fix your phone.
_____________________________________________________________
Use the EFS explorer mode and check the maps.
If there is a map named TOTO and a map LGAPP.
First rename the map LGAPP in to any name you want or change
it like this AAAA.
Secend Rename the map TOTO to LGAPP.
Delete the first map you renamed the LGAPP.
When your finished choose disconnect and wait until the process is done.
You will see the phone starts up in a normal mode if not then
you've to reflash the phone.
I hope this will helps.
May 25, 2009 | LG KU990 Viewty
Samsung instinct. problem: download mode Mode: Emergency Port: USB
Put the battery in the freezer for 10 minutes, then put it in the phone and try again. It worked for me.
Nov 20, 2008 | Lands Phones
Samsung Instinct Cell Phone Logo
1,399 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
