Question about RCA Televison & Video
Where can I find a manual for RCA VH920 Video Source Selector?
I have a brokzonic tv and a unversal remote control i need a code for tv to work
Posted on Dec 04, 2009
The source selector of my onkyo A 807 runs away
HI try this video it worked for me. :)
http://www.youtube.com/watch?v=0Xfm-9jCmjE
Apr 09, 2013 | Onkyo Integra Intergrated Stereo Amplifier...
I just purchased a DS9106PK 9" portable DVD player.....the manual does not explain the Source button, can you tell me what it is used for?
The source button is used to switch video source such as the video input at the back or the vdeo at the built in player.TV tuner ..Just like the amplifier reciever it is called as auxiliary input selector.thank you.
Jul 27, 2011 | Audiovox DS9106PK 9 in. DVD Player
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
I connect the cable,it doesnt show anything!I try the auto channel search for both cable and antenna,it doesnt find any channel at all!it says-no signal..-rca 20inch sdtv truflat.dual combo with dvd player...
I assume you tried the cable on a working TV to make sure there is a signal on the cable line and that the cable terminal is OK. See if you can control the input selector and set it up for RF or TV reception. If OK, try to tune in channels manually or in auto mode. Do this in programming mode. If you notice any noise on the screen, this means the source selector circuit is OK. If there is no noise, the source selector may not be latched to the RF circuit output. Try to feel the terminal at the back of the TV set. If it feels like it moves when pressure is applied in various directions, chances are the solder connection for the terminal onto the circuit board may be faulty. Resoldering them would be easy for DIY enthusiasts. If it isn't the culprit, try the DVD. If it works fine, then the video circuits must be ok. The trouble could be from the video source selector circuit backwards to the RF block. Usually an IC senses the power condition of the DVD player. If it senses that the player is ON, the IC latches on the signal coming from the DVD player. See if there i a separate power button for the DVD. More later, please post a feedback
Aug 25, 2010 | RCA TruFlat 27F520T 27" TV
Where to connect an xbox 360
Connect the 3 RCa cables Yellow, Red, White to Video 1 in on the back of the receiver then select video 1 on the source selector on the panel display.
Aug 09, 2010 | Denon Audio Players & Recorders
RCA rs2600 every thing works but the radio.When the source is switched to AM or FM no sound comes from the speakers.The sound works fine with the CD or tape.
Try to clean the selector mode switch with a contact cleaner like "electra"that safe to all surface plastic or metal.If still the AM and FM not working.You better replace the selector with identical rating parts.
Hope it may helps;
DON'T FORGET TO RATE:
RegardsVOTIT
Jun 12, 2009 | RCA RS2600 CD Shelf System
Trouble getting a picture with a source selector
The input on your television monitor must be set to view the composite with the S video cable. You will not be able to view the component video unless you also have component video outputs going from the input selector to the television. After you have done that, you will also have to change your television input from "video 2" to whatever input you used for the component video hookup.
Dec 05, 2006 | Sony STR-DE685 Receiver
External DVD won't play - no manual available anywhere
The tv has a set of imputs for audio and video ,there is a posibility your dvd is not working right,you can also try a vcr by using the rca audio and video outputs of the vcr to the rca audio and video imputs of the tv,that will tell you if the dvd is not working ,the tv should have a switch selector for video and antena or have a channel below 1 called aux.
Oct 02, 2006 | RCA T13208 13 in. TV/VCR Combo
Televison & Video Logo
433 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
