Question about Refrigerators
I have 10 year old Roper refrigerator. Frig is a
I have 10 year old Roper refrigerator. Frig is a plain jane with freezer on top. When the refrigerator ends a cycle, it makes a very loud THUMP. Can you help and thx ??
  • 163 Answers
The thump is your compressor shutting can try changing the rubber grommets but most likely your compressor is just going to be loud until it finally dies.
Posted on Mar 05, 2009
Check fans worrking ok, condenser clear and clean, vents fully open, freezer not iced up solid blocking airflow.
May 19, 2012 | Roper RS25AEXLQ Side by Side Refrigerator
Roper top freezer clicking and not cooling
I would start by changing the relay on the compressor, thats more than likely where the clicking noise is coming from. Whirlpool brands are notorious for that part going bad, especially ion the early years.
Apr 24, 2012 | Roper RT21SKXLQ Top Freezer Refrigerator
Freezer side working but fridge side is not?
Since we know the machine is producing cold, that is a plus. The cold is created in the freezer. From here, a fan moves it through vents into the frig. From the frig it goes back into the freezer and makes a big loop. What you have here is a motor to the fan in the freezer gone out. If you want to fix it yourself I'd be happy to tell you how. If you want to know if it's worth fixing, I would say most definitely. I would expect $60-$100 for the fan motor then labor on top of that. If you have a model number I could look it up for you :)
May 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My roper frig it has water inside under the vegie
clogged freezer drain in freezer. remove cover and work some hot water in and out of the drain with a turkey baster until water runs thru and then poutr more water thru drain until all ice is washed thru. good luck.
Jan 20, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore top freezer frig
check your start relay on compressor. If that doesnt solve it then you need a new compressor. This is all based on the facts the you said the unit is running all the time
May 27, 2009 | Kenmore 63182 / 63184 Top Freezer...
Freezer cold refrigerator not cold
It almost sounds as if your fridge is stuck in a defrost cycle.
The timer for this is often located behind the grill at the bottom and sometimes is constructed with a visible shaft that you can mark to see if it is running at all. Some units are constructed so that the defrost heater and compressor can't be on together, others are made so thoughtful. If you don't see a shaft, you might try an old mechanic's trick of using a screwdriver with the tip pressed against the timer housing and the handle pressed firmly behind your ear for bone conduction. If you hear anything like motor noise during the time the compressor is not on, then the timer is probably OK. If you hear nothing, then it might have failed.
Oct 20, 2008 | Roper RT14DKX Top Freezer Refrigerator
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
180 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
