Question about Canon Office Equipment & Supplies
Canon iRC3170 with E000020-0081 code
This is about a 1.25hr. trip for me, SO, I'd like to be armed with some facts before I go in the morning.
I was last on this machine for jamming out of the top tray. the pickup roller had fallen off into the tray. It's got about 500k on it.
What is the meaning of this code? and what is the reset procedure?
Does anybody with experience on this machine know if this is likely a simple fix or something expensive?
  • spfaff Mar 10, 2009
    thanks Officetech1,
    I clean paper path, drum cavity, and coronas pretty much every time anyway, (and the patch sensor was dirty by the way).
    Its just that I didn't know what this code was, and I had a feeling this was going to be one of those calls where some expensive part was needed that I did not have. But as is the case most of the time, it turned out to be basic common sense maintenance.
    Thanks for the reply anyway. :^)
  • 100 Answers
The patch sensor is dirty, take out the drum unit. under the itb belt , top left you will see two semi flat blaack plastic pieces. Carefull with your hand you can cram a lint free rag up next to the black shinney belt and the sensors and wipe them off. Use a CLEAN soft cloth to clean these senors off.
When the drum is very old it can cause this error, first thing to do is to clean these senors off. 99 percent of the time that will fix ya.
Posted on Mar 08, 2009
Is canon irc3170 economical and good machine with spare availability
well,I have had a few machines and they didn't do well.Constant problem with E 020,on colour developin units...
Nov 20, 2014 | Canon Office Equipment & Supplies
Hi, stationary jam indication with no error code in canon irc3170; why it shows like this. Can enybody help me.
check paper pice in the paper feeding unit and chech p f unit sensor switch may be broken
How can I install "scan" option in display of Canon irc3170 printer?
http://www.usa.canon.com/cpr/pdf/Brochures/copier_c3170_spec_sheet_rev.pdf
Canon Contact Us
According to the Cannon web site, the 3170 series printers do have the scan feature. I suggest you contact Cannon directly for information about the scan feature.
May 01, 2014 | Canon imageRUNNER C3170U Color Copier
When I turn on my Canon iRC3170 I receive an error code E0748 - 4150. What is wrong?
I have a Canon iRC3170 photocopier, when it is switched on it shows this error message E0748 - 4150. What is wrong? Thank you.
Mar 13, 2014 | Xerox DocuColor 12 Printer
Canon irc3170 error code E000013-0000 tell me the solution
Check the fusing unit thermistors and the main unit contacts and fuses.
Jan 22, 2012 | Office Equipment & Supplies
Verify the fuser unit thermistors and the fuser heater lamp.
Jan 05, 2012 | Office Equipment & Supplies
Canon irc3170 errror code 0020-01a8 how can i rectify?
this is error code for atr sensor's reading. Probably on sensor there is toner dust so he can't read the true value. It needs to be cleaned or replaced.
Call service.
Also this error can occure if the developing clutch is rotate constantly, so he is stiring out too much toner.
Aug 21, 2011 | Office Equipment & Supplies
Code E-000004-001 on Canon IRC3170???
You have to get in to service mode. Press the "*" botton once then the numbers "2 & 8" togather, then the "*" botton once and the screen changes. On the top of the diplay touch "Funcation" then "CLR" 2nd colum 3rd one down, then press "ERR" hi light it in blue then press the "OK" on the bottom right of the screen and turn the main power switch OFF on the right side and see if it was cleared. If not you may have a bigger problem.. Good Luck...
Dec 12, 2008 | Canon Office Equipment & Supplies
Canon IRC3170 Trouble scanning
I'll tell you if you'll pay me as I have had to pay you if I would have asked you. Found the solution alone, thanks to you anyway (I did'nt want to pay) so I had to do it myself, took me 10 minutes more.
May 20, 2008 | Canon Office Equipment & Supplies
1,167 people viewed this question
old marine
old marine
