Question about Mitsumi (D359M3 SILVER) Internal Floppy Drive
Brand new Mitsumi internal floppy drive not recognized by Windows
I have a brand new Power Spec N100 PC in which I properly installed a brand new Mitsumi internal floppy drive. It doesn't work and is not recognized by WindowsXP Pro. I double checked installation and it's correct. I had this in a different computer for a short time and it worked just fine. What else should I do?
  • k4950g May 11, 2010
    A thought. Do you have the SCSI cable connected correctly to the drive. It's possible it could be installed 180 degrees backwards and it won't work with any OS. Floppy drives have the SCSI cable connected backwards, or 180 degrees to the drive, compared to the IDE or SATA drive cable configurations.
  • Jim Scott May 11, 2010
    have you got another drive connected to the same cable ???
    Problem Solver:
  • 18 Answers
Check the BOIS setup. Press on boot and see it the Floppy drive is turned on.
Posted on Oct 06, 2010
Why my "MITSUMI FLOPPY DRIVE" not recognized in windows 8
You might have a driver issue, check if the manufacturer has a specials driver for Windows 8, it should work straight out of the box unless you have a connection cable issue, or you might have killed it if you wasn't wearing anti static gloves.
Apr 27, 2016 | Mitsumi (11-08004) (1108004) External...
Does the product come with A/C adapter, drive-to-PC connector cable(s) and driver disk?
Please note the Mitsumi D509V2 Floppy drive is an internal drive and will not need an AC adapter. It should connect to the output connector of the PC power supply. These use an old 34 pin cable and you have to be careful if your PC motherboard can support this connection. Most of the present motherboards have high speed SATA interface. Also it may be hard to find drivers for Windows7 and above. So unless you have a WindowsXP PC you will not be able read it.
If there is any specific information you need please provide your question in the comments field.
Aug 14, 2014 | Misc - MFG D509V2 Mitsumi D509V2 5.25...
Mitsumi D359M3 driver for Win Wista, 7
You shouldn't need one. You PC bios should pick up the drive when you turn your PC on.
Look in "My Computer" the floppy should be listed there.
Floppies only hold about 1.44 Mb of data Its worth mentioning that these drives are more or less obsolete now, flash/USB drive hold much more data, more now than CD's (700Mb) and
DVD's (4.7 Gb) and now with SD card usb adaptors almost as much as Blueray disks (25 Gb)
Aug 26, 2011 | Mitsumi (D359M3 SILVER) Internal Floppy...
Can't find drivers for mitsumi floppy drive D3553FUE
floppy drives are installed on most newer operating systems. When installing a floppy drive, you do have to be certain the floppy driver is enable in the system BIOS. That is generally the problem when you cannot get a computer to recognize a floppy dirve.
Dec 23, 2010 | Computers & Internet
Windows dectect my floppy mitsumi d359m3 but did install driver or could not find it
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 21, 2010 | Mitsumi (D359M3 SILVER) Internal Floppy...
Can I install a Mitsumi d359m3 floppy in my HP Pavilionj M9517c?
Yes. There is a floppy drive connector on the motherboard that is in your HP Pavillion M9517c, which means you can indeed install a floppy drive if you wish.
Jul 19, 2009 | Mitsumi (D359M3 SILVER) Internal Floppy...
External floppy drive does not work on this pc, states it's missing code37
Try unplugging computer power cable for 10 minutes, if computer is a laptop also remove battery for 10 mins, so to cut power to computer, this will solve problems caused by electrostatic charges on computer usb.
If it still does not work, than it means that windows drivers for usb are not working properly, in this case you will have to reinstall the system.
Jul 31, 2008 | Mitsumi (11-08004) (1108004) External...
FA404M installation
The internal USB cord is made for the memory cards, install the floppy ribbon for the floppy disk. Don't forget to attach the power also.
Sep 01, 2007 | Mitsumi (FA404MBLACK) (fa404m/black)...
3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
Feb 21, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Mitsumi (D359M3 SILVER) Internal Floppy Drive Logo
233 people viewed this question
Top Mitsumi Computers & Internet Experts
David Payne
David Payne
Are you a Mitsumi Computer and Internet Expert? Answer questions, earn points and help others
