Compaq laptop...when click user name laptop turns off
Compaq laptop...when click user name and log in, the laptop starts and then says logging off
  • rick0708 Mar 23, 2009
    Compaq evo n610c - when I log on as soon as the desktop screen appears the computer immediately logs off back to the sign in screen.
  • Lionel Rudling
    Lionel Rudling May 11, 2010
    Have you recently changed from a domain (company network with a serverf that you log onto) to a workgroup?
    What is the last software you installed?
I hit lock instead of log off last time I was in my account
Try to start in safe mode - press F8 as the laptop is starting
Mar 01, 2014 | HP Compaq Presario CQ60-249US Notebook
How do i login on as administrator on my computer?
Login With the Administrator Account in Windows XP Professional
Click the "Start" menu and then click "Log Off."
Click "Switch User" when the prompt screen opens.
Press "Ctrl," "Alt" and "Delete."
Click on "Administrator" when the "Log on to Windows" screen pops up. Type in the administrator password, if applicable.
Click "OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and allow it to continue through its startup process. By default your computer will simply load directly to the primary user account (usually the administrator account), but if there are multiple users on the system it will load to the account login screen.
Use the mouse to click on the administrator account from the list of available accounts to log on. This step is only necessary if you've customized Windows Vista with more than one account or you have set the operating system to load the login screen first.
Enter the password required in the password field to log on to the administrator account.
Click the "OK" or "Log On" button once you have entered the password. This button may be labeled differently depending on the version of Windows Vista or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows Vista environment by clicking on "Start" and then "Log Off." As soon as you have logged off, you will be returned to the login screen where you can choose the administrator account from the available list.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Compaq tc4200 Tablet PC
I have forgotten my password for logging on to windows xp. is there any way I can reset the whole computer and start over.
No problem! We can recover Windows XP admin password.
Just download our windows password Recovery Tool 3.0 to recover your lost Windows passwords.
How does it work?
Just use the box below to download the utility. This is a ".exe" file which will burn itself onto a blank CD. Then pop the CD into your locked PC, and
boot from the CD.
If you have an Internet connection on your locked PC then it will automatically upload the encrypted password to our server for decryption. Once
decrypted, we will send you an email advising you where to log in to view your Windows password.
If you don't have an Internet connection to your locked PC, you can extract the encrypted password to a USB stick and upload manually to our website for
decryption.
It supports usb flash drive too.
Forgotten xp logging password
Nov 23, 2010 | Compaq Presario 700 470024-192 Notebook
Logging in problems
Download minipe, put it on an usb stick, go in the bios by pressing del or f2 when your laptop just starts booting and change the boot sequence to usb first, when in minipe at the harddisk part press on chkdsk.
Jun 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
I forgot my password so when i go to start my computer it wont power up with out it is there any other way i can bypass this?
Hi
If u r using Windows xp den press CTRL ALT DEL At a time u will get a window user name and password
there in user name type Administrator and if u hav given admin password while instaling giv that r else just enter
it wil log on and den u right click on My Computer and go to Manage
there u see users and Accounts double click on it and click on users there u see your user name just right click on ur user name and set password .
Apr 09, 2010 | HP Compaq Presario V6000T Notebook
Start Menu Picture Disappeared Suddenly
Turn the Welcome screen on or off It sounds as if you accidentally turned off the welcome screen. Here's how to turn that function on and off:
To turn the Welcome screen on or off
You must have a computer administrator account on a computer that is a member of a workgroup or is a stand-alone computer to turn on or turn off the Use the Welcome screen feature. Logging on at the Welcome screen is not available on computers that are members of a network domain.
  1. Open shortcutcold.gifUser Accounts in Control Panel.
  2. Click Change the way users log on or off.
  3. Do one of the following:
    • To specify that users log on to the computer using the Welcome screen, select the Use the Welcome screen check box. A user logs on to the computer by clicking his or her user account name on the Welcome screen. If a password is assigned to the account, the user is prompted to type it.
    • To specify that users log on to the computer without using the Welcome screen, clear the Use the Welcome screen check box. The Welcome screen will no longer appear when you start the computer. To log on to the computer, type your user name (and password, if you have one) in the standard Log On to Windows dialog box.
note.gif Notes
  • To open User Accounts, click Start, click Control Panel, and then click User Accounts.
  • Fast User Switching is available only when the Welcome screen is turned on. For more information, click Related Topics.
I hope this helps. Please let me know if you require further assistance.
Feb 26, 2009 | Microsoft Windows XP Professional SP2
How to reset password on a Compaq Presario S6000CL
Do you want to reset a password for log in? Or into bios.
What you could do is log into windows threw safe mode. to do this press f7 during log in ( somes times it could be f8 or f9 just keep pressing them all, not at once, till it asks if you want to start up in safe mode) from their log in as the admin account open command prompt by click start then run then type cmd then ok.
You will ee a black dialogue box in their type this
net user user name*
of course instead of the user name you would put what ever the username of the account you want to change the password of
after you hit enter (after typing net user username*) it will ask what u want the new password to be enter that and then reenter it if it asks then restart in the normal way you always do and enjoy your new password
Hope this helped
-Ryan
-Please Vote if this helped.
Feb 18, 2009 | Compaq Presario S6000CL (DT072A) PC...
To access recovery options log on as a local user
command prompt: click on start>run then type in "cmd"
admin accout: click on start>control panel>administrator accout
Don't forget to rate this solution before you log off
Oct 27, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
