My Gateway Crashed And I Took The Hard Drive Out And Put It In Another Computer And Upgraded Windows Me To Win Xp And Now When I Turn It On The Best I Get Is A "Failure To Boot" Message. What Do I Do?
  • Timothy Bright May 11, 2010
    Try to reformat the hard drive and install Win XP. If does not work, your hard drive is corrupt and you will need to get a new one.
  • 29 Answers
Put the XP disk in the computer and start the computer. Find the option repair MBR. This may be all you need to do.
If this fails put the drive in another computer and check the disk for errors.
Check the jumpers on the drive. Should be set to master. Have you verified the BIOS settings.
Does Gateway have its own version of windows. If so it may be the problem, as such versions are often model specific. Found that to be so with Toshiba.
Must install on a computer of the same model if problems are to be avoided.
Posted on Mar 05, 2009
    Problem Solver:
  • 9 Answers
Do a Repair Install using the WinXP CD.
Don't go into the Recovery Consol, but continue with installing Windows. Eventually it will detect a previous installation and offer an option to repair it. It it does not detect your previous installation, quit the installation or you will lose your data.
This should fix the problem which is likely that the boot sector on the hard drive is corrupt without affecting your data.
How to format/install SATA 2TB hard drive (BARRACUDA) in Gateway GT5098E, Win XP Media Center Edition 2005?
Windows XP doesn't support SATA. You will need to use a program such as Nlite to integrate sata drivers into a new Windows XP disc. Once you have a disc with sata drivers just boot to the disc and follow the prompts to format the drive.
Jan 04, 2013 | Gateway "HITACHI DESKSTAR 0S02861 2TB...
Brand and model of acer aspier am5641-b5560
If I understood you well, the XP OS installed on WD IDE HDD belongs to another computer, in this case you cannot simply install it on your Acer computer and expect it to boot without problems because the hardware is different. What you can do in this case is a fresh Windows installation.
Feb 20, 2012 | Acer AM5641-B5560A Desktop PC & Monitor...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
I have an older Gateway laptop that I rarely took out of house
you'll have to buy a new but tough to find 2.5'' serial-ATA hard drive, this should solve your problems but you'll have to reinstall any operating system and also all of the data on the current hard drive will be lost.
Apr 25, 2010 | Gateway (M520HD80G) Hard Drive
PC Will Not Boot
hi there
i do agree with you about the ribbon cables please make verry sure that they are connected right ie set as master or slave also make sure that the ribbon is tight and then make sure that you boot into bios and see if the computer can recognize the drive and see if it is set to master or slave and see if there are any jumpers on the hard drive that match with what bios is telling you cause if the bios is set to master and you have the jumper set to slave it will not work
Mar 05, 2009 | Gateway Computers & Internet
Mitsumi cd-rom fx4821t wont work
have you installed any software for compiling the data and writing it on the disc....
try to use nero and tell if it shows any error
Aug 31, 2008 | Mitsumi (CRMC-FX4821T) (crmcfx4821t)...
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
Feb 21, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Computers & Internet Logo
56 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
