Question about Gateway Computers & Internet
PC Will Not Boot
My Whole System Crashed So I Took The Hard Drive From My Gateway Pentium III And Put It In Another Computer And Up Graded My OS From Win Me To Win Xp And It Won't Boot, And It Gives Me A Message "Failure To Boot". What Do I I'm Thinking Either It's Not Recoginizing My Hardware Or I Made A Mistake In Ribbon Cables. Please Help.
  • jrcolbert
    jrcolbert May 11, 2010
    you cannot take a hard drive out of a system and put it in another system and do an upgrade and then try to put it back in another system, no.
    You get a windows XP cd and perform a full install on the hard drive in place on the computer it is going to reside in. That is the only way that will work.
  • Gateway Master
  • 3,051 Answers
Hi there
i do agree with you about the ribbon cables please make verry sure that they are connected right ie set as master or slave also make sure that the ribbon is tight and then make sure that you boot into bios and see if the computer can recognize the drive and see if it is set to master or slave and see if there are any jumpers on the hard drive that match with what bios is telling you cause if the bios is set to master and you have the jumper set to slave it will not work
Posted on Mar 06, 2009
Gateway zx4351 operating system missing
When did you get this Gateway? Where did you get it? I assume you mean that it has no OS, cause Gateway does NOT make an operating System. Need more details, please!
Nov 08, 2014 | Computers & Internet
Can i replace the hard drive in my gateway zx6800
Yes, you can, but getting the zx6800 back cover off is a real pain. Does it boot to the Gateway screen? Tell me what happens when you boot. You may be able to do a system Recovery. take a look at this: http://gateway-us.custhelp.com/app/answers/detail/a_id/2631
Dec 28, 2012 | Gateway ZX6800
I have a Panasonic Toughbook CF-28 Mk III P3 1Ghz 512Mb Ram , I have installed a brand new DVD rom Drive in the MP Bay it reconises in bios also reads upon first post however, will not boot from any os cd...
Some bios menu allows you to boot from USB. (Some are locked this option by makers.)
Run safety mode and try again to see whether your DVD rom is working.
Best way will be go to device manager; go to properties of DVD rom; go to driver and click roll back driver.
If this is not working (in case), uninstall driver and reinstall it.
May 29, 2011 | Panasonic 30gb laptop hard drive for...
I own a Gateway nv7802u laptop computer that has recently crashed. When I turn the computer on, I get the normal Gateway startup followed by a black screen that says: PXE-E61: Media test failure, check...
Check and see if the hard drive came loose check the bios to see if it is recognized..It is saying there is nothing with an O/S on it and when you put the disk in it does not register a hard drive to restore..Check the hard drive and start the computer up and see if you can cancel the restore and start the laptop up regular..
Mar 28, 2011 | Gateway NV7802U Notebook
Boot failure
Most likely, your hard drive died. Enter the system BIOS to see what it is detecting (or not) for your hard drive(s). If the hard drive is not being detected as I suspect, you could just replace it and reinstall all of your software.
May 29, 2009 | Intel Pentium III , 900 MHz Processor
My laptop(Pentium III HP) do not show the connection with internal Hard disk that's why the computer does not operate and while I tried to install the Operating System the computer didnot show the...
Yes, it's true your hard disk needs to be replaced. Replacing it is easy enough, usually just one screw on the side ofyour laptop and it pulls out, swap the hard drive out and put it back in again. If your laptop supports boot from external device, it can but I don't think yours does since it's only a P III.
Thanks and please take a moment to give this solution a rating of fixya.
Mar 05, 2009 | HP OmniBook XE3 Notebook
Boot Problem
Your Hard Drive is getting weak replace it with a new one , sometimes when it gets weak and get bad sectors it does not take up the OS and Boot bcoz the data written get lost so replace it or do the double check as follows
check ur hard drive is it showing u in Bios the main culprit is ur Hard Drive try re loading ur operating system by formatting ur hard drive otherwise Change ur Hard Drive it has become weak , there is a hard drive checking utility like HDDLIFE try connecting it to another desktop and scna it thru this software see the strength of the hard drive ur self download the trial version from website www.binarysense.com and let me know if it helps ,
basically if u computer boots ok and goes in bios when u press key that seems like ur whole pc is working ok incl RAM the only thing that is responsible for the operating sys is Hard disk it is where all files reside so when it crashes or get weak it doesnt give up files to boot so pc is unable to boot forward
pls do vote me if u find me helping and fixya problem
Feb 23, 2009 | Gateway 310 S PC Desktop
Won't boot up
Buy a new harddrive and install a new OS on it
make sure your old harddrive is disconnected
after the new hard drive is working properly then reconnect your old harddrive and
u will have all your files back unless the old hard drives crashed completely
Oct 18, 2008 | Gateway GT4022 PC Desktop
Hard drive.
since that it crashed, it is more practical that you reformat it, rather than buying new one. it is the system crashed not the whole hard disk and there is a great chance of reviving it , you have the recovery disk with you, then better use it than buying.
have a nice day
ally (allen)
Jun 27, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Restore hard drive and wipe out everything on it
Dell always send with a new computer one cd to restore the OS of the computer.
If you have this CD put it into the CD drive and boot the computer, follow the instructions on the screen.
Or put an windows CD into drive and boot the computer.If you use this second option you will have to download the device drivers from dell support page.
Best regards
Dec 19, 2007 | Dell Dimension 3000® Pentium® 4...
Computers & Internet Logo
179 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
