Question about Brother Office Equipment & Supplies
A COPY WAS MADE OF A FORM, THAT HAD WET WHITE-OUT ON IT.
A COPY WAS MADE OF A FORM, THAT HAD WHITE-OUT ON IT, THAT WAS NOT DRIED, NOW WHEN A COPY IS MADE THERE IS A BLACK LINE THAT SHOWS WHERE THE WET WHITE-OUT WAS ON THE ORIGINAL FORM. HOW CAN I CLEAN THE WHITE-OUT FROM THE MCHINE AND WHERE SHOULD I LOOK?
You can lift the auto sheet feeder and clean the scanner glass that the originals scan over which is now covered in white-out
Posted on Mar 06, 2009
Garmin nuvi 1350 got wet
Liquid and electronics don't mix. You can cause more damage leaving the power applied to the unit when it is wet. Water is conductive due to the metals found in water. This can short out components and damage them.
Electronics that get wet need to be taken apart right away and washed in a 90% alcohol bath and blown dry with compressed air. The alcohol displaces the water and will dry on its own. The compressed air helps speed up the drying process and blow out any residue in hard to reach places or under parts.
If the unit is allowed to dry without being cleaned, a white residue will form around components and the residue can short out connections.
There are some parts that can't be recovered due to getting wet, like LCD displays, batteries and speakers.
I would suggest taking the unit to a professional to have it looked over. There are some places that won't work on water damaged electronics because even if you can revive them, there is no guarantee they won't die tomorrow and many places will not offer a warranty on water damaged unit.
Mar 25, 2013 | Garmin Nuvi 760 Handheld GPS Receiver
Photo stat in black and white not working
you may have to wipe the ink cartridge flow area off it may have dry ink on it a damp cloth or wet nap should work or you may have to realign the cartridge and make sure it is in the right way hope this helps
Dec 23, 2012 | HP DeskJet Office Equipment & Supplies
Fujitsu split type air conditioner model ASU9RD. Leaks water form the vent. May be a clogged drain? How do you fix?
Typically if you go outside directly behind the inside unit you will probably see a white colored tube, this is the drain and if you have a wet/dry vacuum you can clear it with that. The actual drain can vary but it makes sense to exit and drain asap.
Jun 19, 2011 | Heating & Cooling
My Aprilaire new water pad has a white substance on it. I mentioned this because twice the pad (tworeleased a sticky, mucous substance that plugged the drain line and caused flooding in my basement. The...
Hello,All the pads have a protectant(white) coating because the pad is aluminum and would rot out fairly quickly from getting wet.The slime is bacteria(fungus) not from the coating that forms from stagnant (sitting) water.Make sure the unit is draining out dry after each cycle.With the pad out pour vinegar OR bleach & water (10:1) to kill the mold in the drain pipe.Do not clean the pad at all ,it gets replaced.They sell an inexpensive wet floor alarm at the store that makes noise when wet.
Oct 12, 2010 | Aprilaire 550 Humidifier
Will not load art disk 2 says files are corrupted,,
Examine disk #2 for any scratches or finger marks. These can be cleaned of with a mild detergent and water, drying the disk well before using again. Scratches may be polished off with white toothpaste on a soft damp cloth. Keep the paste wet and polish quite vigorously. When finished and all scratches gone, wash away the paste and dry as above. Do not place disk/s in sunlight! Alternativly, obatain a replacement disk form Broderbund.
Apr 02, 2010 | Broderbund PrintShop Pro Publisher Deluxe...
Copies leaves lines when put through the feeder,but not on the glass .......have cleaned and sprayed air can everywhere I can think of The Hp Printer is HP 3055 All in One printer
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | HP LaserJet 3055 All-In-One Printer
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Unwanted verticle line on fax copies
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 560 Plain Paper Fax
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
173 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
