Question about Haier HVT12ABS Compact Wine Cooler
Runs but does not cool. Can you suggest hot to fix?
  • 111 Answers
Check the fan motor in side the unit , leave the 2 fans alone. CN connector on Circuit board should read 2-8 volts or test fan with battery 5 -6volts...
Posted on Mar 07, 2009
  • ramon49
    ramon49 Apr 02, 2009
    No compressor on thermoelectric. if red /green led run when first plugged in, then it's the fan in side the cooling box, replace..
  • 163 Answers
Check to see if you can hear compressor turn on.if not then the relay may be bad.could also be a leak in the system.
Posted on Mar 05, 2009
John Deere 737,Kawasaki motor, gets hot start's missing on one cylinder, cools off start's run fine, could it be the coil breaking down
possible so have the coil checked
could be from dirt and grass blocking the cooling fins of that cylinder causing the problem with mixture
if you spent that much with a dealer and the problem was not fixed maybe you should complain about the cost and the failure to fix the fault
May 13, 2016 | John Deere Garden
When the car is driven and motor gets hot the car shuts down but when it cools down it starts and runs fine again until it gets hot
IT is most likely the thermastat but i would not suggest driving it until it fixed as that could cause the head to crack witch costs around $213 - $250
Jul 27, 2012 | 1993 Dodge Dynasty
Radiator fan switch or coolant temp sensor however it is called is not activating the radiator fan when temperature is high. . .iS THERE a way to by pass this switch or sensor so it can activate the...
CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.HOT WIRE COOLING FAN TO MAKE SURE COOLING FAN MOTOR IS WORKING. IF COOLING FAN RUNS WHEN YOU HOT WIRE FAN MOTOR.CODE SCAN FOR ECM FAULT CODES.REPLACE THE ENGINE COOLANT TEMPERATURE SENSOR NO NEED TO BYPASS THE SENSOR.
Aug 22, 2011 | 2004 Suzuki Aerio
2002 malibu runs hot.
Sounds like you have a faulty head gasket or maybe a cracked head.This can cause overheating and the check engine light to come on.The code for the o2 sensor is probably caused by coolant getting into the exhaust system and coating the sensor.The coolant fan may work but it cannot remove enough heat from the rad to make the engine cool off.Try some engine coolant stop leak to see if it will help.This maybe only a temperary fix.Let me know if you need more.MOE
Jun 22, 2010 | 2002 Chevrolet Malibu
Starts runs until warm stops
I would replace the coil. and condenser.
Oct 18, 2009 | 1989 Jeep Cherokee
My honda v65 magna runs hot in stop and go traffic
V65s are notorious for running hot in stop and go traffic as it has a liquid coolant system and no cooling fins on the heads or cylinders. An easy fix is to wire in a switch to turn on your electric radiator cooling fan and switch the fan on and leave it on when you are riding in town.
May 05, 2009 | 1984 Honda VF 1100 C
My 2000 eclipse 2.4L runs hot at idle only
Your car should have a High and low speed connector there. That would cause the problem you described, if the PCM sees the temp at about 195 the low speed fan should kick on, if that fan doesn't provide enough airflow it kicks on to high speed to cool quicker. in your case the low speed is non existent and the computer is simply waiting for the temp to raise to the point where it triggers the high speed relay.
Feb 25, 2009 | 2000 Mitsubishi Eclipse
Haier HVT12ABS Compact Wine Cooler Logo
354 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
