Question about Whirlpool WFW9200S Front Load Washer
Door would not unlock - got an error code f-22 what does that mean?
When i try anything drain/spin all im getting is a clicking noise and the door still locked. Same problem. My washer is only 2 months old and the door won't open and there are clothes on the inside that I can't get to.
  • subway272 Mar 05, 2009
    The error code originally was F22. I got the door open as explained above, from inside but the washer won't run a cycle now. It just beeps when I press and hold the start button on any cycle.
  • 40 Answers
There is somthing in your drain pump or your drain pump is bad or both, take the three screws from the front bottom panel and in the middle you will the pump housing round and plastic you can take the cap out and it has a trap in it . get some towels ready and under pump then take out slowly make sure there is nothing inside housing if so remove it then put cap back in and start drain spin if pump sounds better then put into wash then into drain and spin to check it out to unlock the door you can do so by putting your hand up the right side behind the front panel and feel the door lock from the back unplug unit from wall of course you will feel a round flat peice of plastic at bottom of lock pull down on it and will unlock door after clearing pump and unlocking door try unit out if still acting up replace drain pump part#280187 about $120
Posted on Mar 05, 2009
  • 163 Answers
Your door switch may be going bad.try pushing the door in and hit drain spin and if that works then it will unlock.I need to know what code is flashing to help further.hope it helps.
3 Suggested Answers
SOURCE: the washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor can find the part at It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Posted on Apr 11, 2009
  • 41 Answers
SOURCE: Washer drains but will not spin
Does it agitate and run through the cycles? What mod.number? It may be the motor drive coupler. If it is a direct drive. The transmissions are usually not the prob. The couplers are. They are fairly easy to change. from undrneath you can remove the water pump by prying off the retaining strapps (2). Pull the pump off. Remove the screws retaining the straps (2) holding the motor and pry them off. Pull the motor off and the cooupler consists of 3 parts. 2 (usually) plastic and one rubber. The plastic may be broken or the rubber may be worn out. You can usually tell. The plastic parts also crack around the shafts and slip. They are avalible online for about $14. Usually changed in less than an hour. Trying to help but I have limited info here.
Posted on Aug 06, 2009
How do I get washing machine door to unlock?
The error F26 does indicate a fault in the door switch circuit. See the image below for a complete listing of what can cause this error. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close. One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
Unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Jun 16, 2014 | Whirlpool duet Washing Machines
What is f-22
F22 means you have a door lock problem you need to unlock your door to correct the problem
May 22, 2014 | Whirlpool WFC7500VW Washer
Error code f-28
F28 means your washer is locked and not unlocking. To unlock your washer take off the bottom access panel by removing the 3 bottom screws. Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Click if helped.
Apr 30, 2013 | Kenmore HE2 Washing Machines
Frigidaire frfw3700lw0 drains but not spinning
Hello ctilton2001 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 06, 2012 | Frigidaire FRFW3700LW Washer
Im getting a "LO" error
The LO error code means the LID OPEN
Here is what the techicians service manual say to check
LO Door failed to unlock Door lock monitor switch does not indicate to the machine control board that the solenoid in the door lock mechanism retracted and unlock the door. 1.Check for debris inside inside the door lock mechanism, which may be jamming the lock solenoid. 2.check wire connections in harness leading from machine control board to door lock mechanism.
3.Check the door lock monitor switch for welded contacts.
4.Replace responsible component.
Jul 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
Bosch Washer WFMC3200.
Contact a Bosch technician. You may have to at least pay for a service call.
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
Error Code OE and Door will not unlock
error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly.try running the spin cycle alone till the water empties completely.If the problem still continues it means that the pump is clogged where you cant reach, since you've tested with the drain hose.
Dec 16, 2008 | Washing Machines
I get an error code: F dU and my washer won't drain properly
I too, had the same issue with the door not opening. My solution was to unplug the power cord and then plug it back in and press the green button's as if to start a cycle and while it starts putting water into the washer I put my knee and weight into the door lock area and held pressure from my knee and press the red stop button until the lights went out, and I took my knee off the door lock area and opened the door!!! No taking off the lower panel.
If this works for you too please email me
Nov 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error message f 09 and f 02
remove bottom panel..reach up from bottom to door lock area pull down on small tab hanging there door will release ..dip all the water out you can vac will help..remove the knob on front of pump have towels handy clean pump trap ck pump impeller for obstructions reassemble and ck if problem persists may be loose impeller on pump
Aug 27, 2008 | Kenmore 46462 Front Load Washer
well all you have to do is hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
Jan 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW9200S Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
