Question about Pentair MINIMAX NT TSI IGNITER
MIni-Max 400 heater cycling
When we have our Mini-Max 400 heater set to heat the spa, the heater cycles on and off. I had a pool repair person replace the flow valve, then he used high pressure to clean out the pipes, and a ton of white crud came out. He also replaced the blower because it was leaking and sucking air, which may have caused improper pressure for the heater to work correctly. After $1000, the heater worked like a champ for a few uses and the spa would heat up in 15 minutes, but now it's cycling on and off again and the spa takes 1hr to heat. The manifold, where the flow valve is installed, seems to get very very hot, then the heater cycles off. I'm not sure if the repair person checked the pressure switch, which I heard could be the problem. The repair person said the heater core could be clogged, but he said this would require me to refinance the house to pay for this repair. Any ideas before I trade-in the wife to pay for more repairs?
  • dwfilice Mar 06, 2009
    Well, the problem may have been solved. The repair guy stopped by and said the filter basked was quite clogged. I just cleaned it a week ago, but if the lack of flow from even a slightly clogged basket caused the heater to malfunction, then I will clean the basket more often. Usually a sign of a clogged basket is the Kreepy Krauly not working, and it's been working just fine.
  • bruba Apr 16, 2009
    I have the same problem. Happened last winter 2007 - 2008 service man replaced the flow valve, burners clean, worked a little bit and back to the same problem. Watched the heater, heats for about 4-5 minutes all lights green, then you hear an electronic relay disconnect then the red service light comes on and the heater shuts down, 2 minutes later the red light goes out the relay connects, burner fires and the whole process repeats. Any suggestions?
  • 366 Answers
Sounds like you may have a water chemistry problem more than a heater problem. High pH coupled with the heat of the exchanger in the heater will allow the calcium in the water to precipitate and scale the tubes of the exchanger. Make sure your water is balanced, pH 7.4-7.6. Water balance factors include pH, total alkalinity, calcium, TDS, and temperature. Use the langlier saturation index to determine your water balance. If your water is balanced, you may have a bad thermal governor. If you hear the heater water hammer and bang around and then shut off, you definitely have a scale buildup in the heat exchanger tubes. Hope this helps...
Posted on Sep 17, 2009
We have laars mini therm boilers,JVH225NCSS One goes through its start up Pilot burners lite,But shutdown within seconds, it continues to cycle but will not burn as it should. I've cleaned burners..
Might be the safety thermocouple is faulty or the pilot light is not heating the thermocouple bulbs - perhaps the brackets have become distorted and need realigning.
Mar 01, 2016 | Mini Pool & Spa
My mini max 100 is kocking and short cycling
not enough water flow if you have a bypass shut half way
Nov 25, 2013 | Pentair MiniMax 100 Aboveground 100,000...
When I turn my mini max plus 400 heater on it clicks then nothing happens, what's up with that
If it is clicking it is trying to fire (calling for heat). This indicates that the internal safety loop Tstat, and IID are working. It is either a bad gas valve, your ignition wire, or lack of gas. If the gas line had been open for servicing for any length of time it can take a while for all the air to get out. Best call out a tech to do the repair, you are literally playing with fire.
May 15, 2012 | Pentair Minimax NT Heater
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
NT mini max not heating at all - won't fire
wow t pool service is just guessing i guess . weel let see do u have a pilot if yes do u hear a click if yes clean t burners if not check 24v at t brown wir e for t gas valve if v replace gas valve if not replace ignition control . do u have any code on t back or t front this help a little.
Jun 14, 2009 | Pentair Minimax NT Heater
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Won't ignite
make sure wiring is correct for 220 vs 110 wired for 220 from factory if 110 see inside panel move wires ignitor is not getting hot enough
Jun 02, 2009 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Pentair MINIMAX NT TSI IGNITER Logo
1,766 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
