Question about Konica Minolta magicolor 5430 DL Laser Printer
Magicolor 5430dl, "No Toner Magenta" error
Magenta no toner alert , when there is in deed toner. This is for my
Magicolor 5430 dl.
Why is it saying there isn't toner ??
I did do alot of color printing today?
Hi this might work, have you tried to remove the toner and re-seat it??
If this doesnt work very carefully take the toner somewhere well ventelated preferablly outside and give it a good shake for about 15-20 seconds, this frees any clogged toner there may be.
Failing all of that you would want to try outting a new toner in and see what happens.
Posted on Mar 23, 2009
Hello! magenta toner is new, but i have message "magenta toner out"
Make sure you remove the zeal/lock the knob if you already did that, Open and closed the main door while the machine is On. Wait for 2 mins to machine to adjust for the New toner.
Oct 17, 2014 | Konica Minolta magicolor 1680MF -...
Magicolor 5430 dl doesn't print magenta
Please check your magenta cartridge if they are properly installed.
Make sure that your magenta cartridge are not empty.
Make sure that you are using the original konika minolta cartridge and not just a refill one or replacement one.
Aug 20, 2009 | Konica Minolta magicolor 5440 DL Laser...
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta 5430DL error code 111112
I couldn't find the install disks so downloaded the driver from the Konica website, un-installed the software and re-installed it. After calibrating the colours everything seems fine now.
Oct 01, 2008 | Konica Minolta magicolor 5430 DL Laser...
Toner Cartridge reads empty
did you change the microchip with the cartridge. also i believe that you can reset the levels in the menu
Aug 20, 2008 | Konica Minolta magicolor 5430 DL Laser...
Error 2408
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica magicolor 5430 smuding all over page
also there can be problem with the waste toner pipes, that the waste toner wont go away and smug the page. check waste toner box also check transfer belt and pc drums that they are clean.
Jun 03, 2008 | Konica Minolta magicolor 5430 DL Laser...
Konica Minolta magicolor 5430 DL Laser Printer Logo
380 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
