Question about ASUS A8V-E Deluxe Motherboard
Hi. I think I have a problem with my son`s ASUS A8V-E DELUX motherboard. All fans and LEDs are OK but it won`t fire up or wake the monitor (I did try a second monitor. Thought it was the graphics card so got a new one but no go. Then I changed the psu but still the same, next I tested the chip but that is also working. After taking out the RAM memory and cleaning it still nothing, so I fired it up without RAM and silence not a beep in sight (if you know what I mean). So is the board dead or is there somthing left that I can try? With many thanks for any help, Nigel.
  • 385 Answers
There is one more thing I know you haven't tried yet. That is the CMOS battery. If that is bad, it would cause this problem. It's not a definite fix but it's something to try, it worked for me.
Thanks and good luck to you!
Lolita
Posted on Mar 05, 2009
    Scholar:
  • 67 Answers
I think you've done pretty much everything I would have done. If you have a spare Power Supply Unit (PSU) laying around, I'd try that in case there's any issue with voltage. Aside from that, maybe different, yet compatible memory may be another step.
Can you recall if there were any lightning storms or power outages right before this PC stopped working that might account for a shock that could have hit and damaged the board? Motherboard and PSU's are the first to go generally when something like that happens.
I have ASUS A8V-VM Motherboard a8v uayvz with amd 3700, what upgrades ave available ?
Hi Cheqel,
Here is the weblink which has all the updated version software for your motherboard.
http://usa.asus.com/Motherboards/AMD_Socket_939/A8VVM_SE/#download
This will be great.
Jul 06, 2011 | ASUS A8V-VM Motherboard
MY MOTHERBOARD IS ASUS P5PE-VM. NO DISPLAY OR ANY REACTION TO MY MONITOR.
Hard to know the problem without any details.
Is the power supply ok.
Is the monitor ok.
Is the keyboard ok
Do you see any leds on
Is there any sound of hard disk activity
Try to download a copy of the user manual from
http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5PE-VM/e2609_p5pe-vm.pdf
and check the status of LED etc.
May 18, 2010 | ASUS P5PE-VM Motherboard
Asus A8V-XE motherboard keeps shutting down, just put new power in and it is still doing it
Hi
Kindly see if the CPU fan is working properly. This might be a system shutdown due to overheating components
Hope it helps..
Thanks for reaching Fixya.
Leave comments for further assistance.
Apr 03, 2010 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
Asus motherboard a8v-vm jumper setting motherbord on but cpu fan not ON
You do not use a jumper to run the CPU fan. There will be a small 3 or 4 pin plug near the CPU mount and you can plug the wire from the fan into that plug only. If the one on the motherboard has 3 pins and your plug has 4, you can use it anyway; just be sure the slot on the back of the plug matches the side of the one on the board.
Oct 28, 2009 | ASUS A8V-VM Motherboard
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
http://support.asus.com/download/download_item.aspx?product=1&model=A8V-VM
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | ASUS A8V-VM Motherboard
Asus A8V-E not start
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Jul 24, 2009 | ASUS A8V-E Deluxe Motherboard
Hi sair mere pas asus a8v-vm se motherbord ka adio driver[alc660]nahi hai pls help.
Hello jee,
App iss link se apke drivers download kar sakte hain.
ASUS a8v-vm se
Bas apni operating system select kijiye aur apne motherboard ke drivers download kijiye.
Aur ek baat MUJE RATE JAROOR KARNA !!!!
Dhanyawad
Mar 10, 2009 | ASUS A8V-E SE Motherboard
Mic issues
A8V-VM SE FRONT PANEL AUDIO does not work. The back panel audio speaker port works ok but not the MIC port. I have built over 100 pcs with different motherboards & procesors including several other Asus MoBo both Intel and AMD types. BIOS flas did not help. Asus tech support /knowledge base is useless to find answers.
If anyone has had this problem and solved it , please pot your answer.
Thanks
Oct 22, 2007 | ASUS A8V-VM Motherboard
ASUS A8V-E Deluxe Motherboard Logo
242 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
