BWD 129 after every wash on my BWD129, detergent dispenser is left with full of water that then leaks out. The dispenser has been cleaned, but have not resolved the issue. any help much appreciated? is this programme fault?
  • 163 Answers
Pull dispenser out and clean out behind it.probably using to much detergent or wrong brand.you should get flash light and look deep inside.Is the machine front load or top?
Posted on Mar 05, 2009
  • Kevin howley Sep 16, 2011
    Take the dispenser out fully, remove the blue part and was totally. Works as suction and not drainage with gravity. Ensure it's all cleaned properly and will work
Lg 1370 slight clean water leak on left side of dispenser draw sometimes? solutions please ,
Usually a sign that you are using too much detergent. Pull the drawer out completely and clean it out. The drawer and the casing
May 28, 2014 | LG WM-2277HW Front Load Washer
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
Hotpoint bwd 129 leaking from underneath (left side when looking at the machine) - i have checked the plugs at the back - all okay.
Hotpoint bwd 129 leaking from underneath This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 08, 2010 | Washing Machines
Hotpoint BWD 129 machine starts to fill -
Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
Feb 12, 2010 | Washing Machines
PROBLEM WITH HOTPOINT WASHER DRYER - MODEL BWD 129-ON DRY CYCLE CLOTHES COME OUT STEAMING AND WET. PLEASE ADVISE
If the clothes are coming out hot and steaming, then the water from the clothes is not condensing, it could be a blocked condenser, which will have to be removed and unblocked and cleaned.
The other possibility is that there is no cold water coming in on the drying cycle, this can also have the same effect.
Hope this helps.
Dec 03, 2009 | Hotpoint Washing Machines
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
I have a BWD 129 Hotpoint intagrated washer dryer and lights 1 2 and 4 are flashing what does this mean and do I need a new machine it will not do a drying cycle?
Filter blocked, disconnect hose from under sink connection and drain into bucket. Hotpoint does not want you to change filter, contact Service Engineer.
Apr 03, 2008 | Washing Machines
Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Jul 06, 2007 | LG WM2277H Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
