Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Black line going down the middle of the page
Customer says the fax he recieved from me had a black line down the
middle of the page
Lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Posted on Mar 06, 2009
I have a Brother Intellifax 775 and outgoing faxes all have black lines down the middle of the page. Incoming faxes are good. I have cleaned the scanner mirror and it doesn't help.
Posted on Aug 18, 2009
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: BLACK LINE IN MIDDLE OF PAPER
Open the doc feeder and clean the scanner glass.
The receiver of my FAXes says that there is a black line down the middle of each page. The FAX is a good copy-clear, etc.... but this line has to go. What can I do? Thanks, Donna
Dear Donna,
When a document is scanned from the top portion of the printer, it will loop around and output from underneath. The scanning glass on the far left side will have some debris on it. Lift the the lid exposing the glass portion, inspect for "stuff" on the glass, perhaps pen or white out. You can use a mild soap and lightly dampened cloth to remove any debris.
Good Luck,
Pre
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I am getting a white line down the entire page
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
Apr 26, 2010 | Canon FaxPhone L75 Plain Paper Laser
Faxes are printed with a line running down the
If the line is on the back you need a shop to replace the ink absorber and put in a mylar shield to keep the ink from coming back up on the rollers.
Sep 29, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Samsung fax copying - line on middle of page
check if there is any kind of leank inside the printer. do a manual servicing once.
Jul 28, 2009 | Samsung SASSF560 - SF-560 Plain Paper...
Recieving end gets a page with a black line down the lenght of pa
There is a narrow glass on the left of the scanner glass. look at it ,you will probably see a spec of dust,dirt or debris there. Clean it. If it is on the inside of the glass, you will need to remove it and clean it.Also, lift up the ADF cover and clean the rollers with a cloth and some alcohol.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 15, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Black line down middle of page
Clean off the glass place where the paper passes when you fax. You'll probably find some foreign matter on it. Wipe it off and you should be good to go.
May 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
When we recieve Fax, the paper is very dark
We had the same problem and we switched out the drum and now the faxes are very clear except for a solid black line going down the right side of the paper.
Mar 14, 2009 | Brother IntelliFAX 2800 Laser Fax
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
MY CANON ALL IN ONE PRINTER/SCANNER/FAX HAS LARGE BLACK LINE DOWN
You will probably need to clean the bottom plate and/or the print head to eliminate the problem
Feb 19, 2009 | Canon Pixma MP500 All-In-One InkJet...
Lines going thru the pages of fax i send
you ma try to make a copy see if have lines through the page if does, you may go to document feed unit open the cover you may see a piece glass just use alcohol to clean it should take care your problem
Dec 13, 2008 | Dell 1815dn All-In-One Laser Printer
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
1,906 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
