Question about Westinghouse SK-19H210S Television
Westinghouse sk19h210s won't power on. service
Westinghouse sk19h210s lcd tv won't power on. service center suggested power supply trouble. how do you get the set apart to check for example: power supply, fuse or failed capacitor. set has been working OK for 15 months on amplified antenna.
  • 5 more comments
  • JPfromFL Apr 09, 2009
    We purchased an sk-19h210s at Sams Club 14 months ago. The set has been
    used about an hour a day, we have very stable power on a good quality surge protector. The tv stopped powering on
    (for a bit the blue LED pilot would light for 1 sec and then shut off).
  • retrorewind Apr 10, 2009
    The same EXACT thing happened to me!
    The TV was purchased dec of 07. It was used a few hours a week.
    Now, April 0f 09, it won't power on at all!
    Any advice on fixing it?
  • Anonymous Apr 12, 2009
    I have the exact same problem. I got the TV in Dec '07 from sams for christmas. I rarely use it, but out of no where it didn't want to turn on, and when it did after 20 minutes the picture is jumpy, it won't work on any other ports but the cable input
  • vince67gta Apr 15, 2009
    Same problem here, my Westinghouse sk-19h210s will not power up. I will try several times to turn it on and nothing will happen, then out of the blue I will come home from work and the set will be on. If this is a power supply problem can it be fixed or does i need to be replaced?
  • Anonymous Apr 22, 2009
    I purchased one in Dec 07 and not it wont' power on either. The cost of the power supply is $200.95. Looks as if I will just trash it and buy a different brand. It's **** that it's only a couple months out of warranty and they wont' do anything to help.
  • Anonymous Apr 23, 2009
    I purchased the same set at Sam's in late Oct 07 and now April of 2009 the TV did the exact same thing as others have listed. The power was acting strange then it just went dead. Now it will not power on at all. What a piece of junk especially considering everyone has the same issue just after the 1 year warranty expires. Now you know why they sell these as refurb units for under $200. I assumed my Sams card extended the warranty like Costco does but I was mistaken. I am not longer a Sam's member and have joined Costco.
  • Anonymous May 14, 2009
    I have the same problem, I was told to try replacing the 2200 Capacitor on the power supply... i am gong to try that tomorrow and see what happens..
  • 4 Answers
I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again.
Just be careful and take notes when you're digging into it. And mark exactly where the card cage is before taking it loose.
Posted on Sep 19, 2009
I have taken my Westinghouse LCD TV, model # SK19H210S,. apart now I need a book for dummies! I am attempting to replace the capacitor.Went to Digikey to try to figure out what part I needed and it gives...
Check the 2200 MFD capacitor on the power supply board. If the top of it is slightly domed up, it is bad. Check the top against the other capacitors on the board to see how the tops look. I got a 16 volt 2200 MFD capacitor at my local Radio Shack. It was in the assorted pack of capacitors 272-802 for $4.95. The package had 3 capacitors this size.
Sep 27, 2009 | Westinghouse SK-19H210S Television
Screen black - power to tv is good.
The power to the TV may be perfect but the supply in the Tv that provides power to different areas may be bad and need to be replaced. there could be a bad capictor in the power supply that is cause.
Jul 10, 2009 | Westinghouse SK-26H520S 26 in. LCD HDTV
Won't turn on. Westinghouse SK-32H540S 32 LCD
Try leaving the TV unplugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. Or, it maybe something simple like a blown fuse inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If the fuse doesn't fix it and If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem with the power supply and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 04, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
Model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
Nov 04, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
Televison & Video Logo
2,125 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
