Question about Samsung LN-T5271F 52 in. LCD Television
Ghosting on our Samsung LCD TV
Our Samsung LN-T5271F is just over a year old and for the past month or so we have started getting "ghosting" or shadowing" on the right half of the screen. In addition, we get wide lines crossing vertically across the tv, but after about 3-4 minutes, it all seems to subside. We have cable, but no cable box, and the troubleshooting guide in the manual talks about our cable box....since we don't have one....is there another solution?
  • 1 more comment
  • tdk140 Mar 16, 2009
    Does anyone have a solution to my problem that was posted on March 5th? Thanks.
  • Anonymous May 12, 2009
    exact same situation
  • wweir10554 May 12, 2009
    exact same poblme
2 Suggested Answers
SOURCE: I have a Samsung LCD (LN-T5271F) about 2 years old
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Posted on Jul 21, 2010
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
Samsung TV now takes over 30min to come on
There are a number of Capacitors on the IP/Power supply bd and they have gone bad. Replaced them with the proper Capacitance as the old ones are BUT get the 35 volt Caps. Going from 10v to 35v will fix this problem.
Apr 14, 2010 | Samsung LN-T5271F 52 in. LCD Television
LN-T5271 will not turn on
Its sad to hear that your LN-T5271F TV isn't turning on. Sad to say that there are no user serviceable parts inside (unless you are a professional TV repair Guy) There's probably a blown fuse or a bad capacitor inside. The only way you can tell is to open up the TV and use a tester. I don't recommend that you to that yourself because you might end up spending more. Bring your TV to a local repair guy and have it fixed.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | Samsung LN-T5271F 52 in. LCD Television
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Rnj VINODKUMAR
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Samsung power-up problem
two 2200uF capacitor, two 1000uF capacitors on powersupply board.
Replace it! you will save $300.
Jun 19, 2009 | Samsung LN-T5271F 52 in. LCD Television
Ghosting
Does the monitor do this on all resolutions?
Try changing the refresh rate on the monitor's properties page and see if the effect changes at all.
Feb 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung LN-T5271F 52 in. LCD Television Logo
391 people viewed this question
Henry  Thomas
Henry Thomas
