Question about HP Computers & Internet
When I activate sleep mode my computer turn on again itself.
  • Timothy Bright May 11, 2010
    One or more of your components like your wireless card or LAN card (Networking card(s)) could be set to pull your computer out of sleep mode when it wants to. Turning this feature off may stop this from happening. You can check these settings under the properties of the network connection.
  • 374 Answers
Check your firewall set up if there some program that is blocking your the windows operate and add this to excemption. If still trip off again this particular problem is common to harware problem but sometimes it can be on software problem,You can check this on if you have an extra power supply of your CPU replaced it.The power is tripping off.
Posted on Mar 05, 2009
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Acer iconia a500 tablet shuts itself off
This might sound a little stupid, but 1 is it plugged in when you put it sleep mode, and when u open the screen do you physically have to turn it back on. Sometimes when you put a computer in "sleep mode" and its not plugged in you lose power slowly
May 20, 2012 | Acer Iconia Tab A50010S16u Notebook
I put my laptop in the sleep mode as a requirement for using "Magic Jack" and have using the power switch to go out of sleep mode and activate Vista. I read this could cause problems later but don't know...
On most computers, you can resume working by pressing your computer's power button. However, not all computers are the same. You might be able to wake your computer by pressing any key on the keyboard, clicking a mouse button, or opening the lid on a laptop.
It just need an interruption to wake from the sleep mode so its perfectly ok to do so by any key or by the power key....
For any further guidelines give a comment...
Feb 28, 2010 | Computers & Internet
Laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
Dec 11, 2009 | Computers & Internet
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
LAPTOP WILL NOT COME OUT OF 'SLEEP' MODE
Turn it on, then wait, u will hear the computer turning itself on and off, but nothing is showing on the screen. so make it turn on and off, 3 time.( such as hearing the computer turned off, so that one,THEN IT TURNS ITSELF ON AGAIN, next time it turns off, that count as 2, and so on). on the third shut off then u press and hold the off button, to force it to shut down, then wait. about 5-10min., or less then 5. after then u turn the computer on.it should be on by now. if not try it again. if it happens again try one more time, if it happens again. then there something really wrong with your computer.
Jun 15, 2009 | Nikon COOLPIX L20 Digital Camera
Computer not sleeping in sleep mode.
One possibility is if you have an optical/laser mouse that is on a relective surface and the mouse light is reflecting and triggering the computer to think that there is activity.
More than likely, your network card is keeping your computer from staying in sleep mode as any internet data activity is taking the computer out of sleep mode making the computer think there is activity.
There is an option in the Network Adapter properties that says to "Allow this device to wake up your computer"
Go to Control Panel and click Classic View on the left hand side
Double Click the Network and Sharing Centre Icon.
On the left hand side of the window that opens, click Manage Network Connections.
Right Click on the connected Network Connection. It is probably the Local Area Connection. Right click on it and choose Properties
A new box will open up. Click the Configure button under the Connect Using: box
Click the last tab at the top that says Power Management.
Under the Power Management tab click the square box that is beside: Allow this Device to Wake the Computer to take the checkmark out of the box. Then Click OK at the botton and close all the windows.
Let the computer go into Sleep mode and see if the computer still comes out of sleep mode on its own.
Let me know if this worked for you,
Ry
Apr 03, 2009 | HP Computers & Internet
Model26LB30QD turns itself off not in sleep mode.
There was a glitch in the electrical system. There was nothing we or anyone else could do. We returned the televion.
Jan 09, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
