Question about Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle
My gun fell apart
Okay first things first the gun is about five six years old or more
i was undoing all the screws to paint all the casing with silver
and i took all the pieces out of it, and i mean ALL the pieces out of it
like man, there is not one singtle piece actatched to one another anymore. now i do have evry last piece but i cant for the life of me fugure out how to put it back together
its a ''crosman 177 cal. pellet gun 357 revolver" i dont think that they make them anymore
i dont know if it matters but the us patent number is
4,422,433
yeah i liked that gun alot so if you could like send me an instruction manual or something that will help me put it back together
Sell it to me to fix my gun I need the left grip and the rotory cylinder magazines Do you have these items?
Posted on Apr 21, 2009
2 Suggested Answers
Adrian762
  • 425 Answers
SOURCE: Will not chamber a pellet for Crossman 357 .177 cal pellet gun
http://www.pyramydair.com/site/manuals/Crosman-2100.pdf ,
Read this and make a decision based on the information contained within.
Posted on Feb 07, 2010
How do you take this hvlp gun apart for proper cleaning of the spray gun?
I've found over the years the least amount of times you can tear a spray gun completely apart the better. Usually a real good 'flushing' with lacquer thinner will suffice. I will take the air cap off and let it soak in thinner to dislodge any build up but other than that, I simply run thinner thru till it runs clear out the tip.
I also 'back flush' which involves having thinner in the cup and the air supply hose attached. the air pressure should be adjusted quite a bit lower than what you use for spraying paint.
Then you place a clean shop towel or rag over the air cap of the gun and pull the trigger. This forces air back into the paint cup 'back flushing' the gun. Then take the rag away from the cap and pull the trigger again to run thinner thru the gun the normal way.
IF you still want to tear the gun apart for cleaning you can hopefully get some idea with this video link;
Quick Easy Way to Clean HVLP Spray Gun
Hope this helps.
May 25, 2015 | HVLP Air Tools & Compressors
Spray painting
It depends on what kind of spray gun you have. If you have a HVLP gun the pressure doesn't have to be as high, but you need a compressor that will keep up. The pressure is usually pretty low on these guns, about 15 PSI or less. The paint manufacture will usually give you a recommended pressure to paint their paint. A normal (old style) suction type gun takes more pressure, about 50 PSI. If you are asking this to decide on a compressor size, you will find that a one horse motor on a two cylinder compressor will not keep up. The newer supposedly five horsepower compressor will not keep up consistant pressure either. You need a five horsepower that runs on 220 and driving a belt driven two cylinder compressor minimum. You can get by on less, but have to wait half way during a coat on a car to wait on the compressor to catch up. This may be o.k. if you are just going to paint one car, but if you are looking to do this consistantly, then I would get a five horsepower motor on a two stage compressor. Make sure you drain the air tank of water and use a good air filter to remove moisture from the air before trying to paint. Hope some of this helps you.
Feb 16, 2012 | Bernina Sewing Machines
My weber genesis silver-b (sku # 218446) is 11 years old and has this "peeling problem". Is anyone "sure" that it isn't "paint/enamel" that is peeling on a model that was...
I'ts the same today as it was back then. They still use porcelain enamel. Not paint. A couple of things that could ease your mind. Paint has like a kerosene smell to it. Also, drop a chunk in water for a few days, paint will not dissolve in water.
Jan 18, 2011 | Weber Genesis Silver C Grill
I own this 0525151 and am trying to spray a latex fence stain. worked for a little while, then nothing. I tried thinning the paint with water and a paint thinner product recommended by the Home Depot...
We used paint sprayers every day for years.
Tips come in different sizes. With oil base paints we used the small tip like a 4-11. With latex we used bigger tips, like a 5-17. Really big spray rigs use 5-19. Tip size matters.
Another important thing is to strain the paint. The paint store sells 5-gallon-size strainers. Put the strainer over a 5-gallon bucket. Pour the paint into the bucket. Lift the strainer up, and finally grab it with your hands and squeeze the paint out. Do this in the grass and then wash out the strainer for next time. Put a lid over the paint bucket so the paint stays wet and clean.
We used high pressure sprayers, and then wrapped a filter right over the intake... but the tips would still clog. We had guns with reversible tips ... rotate the tip around, fire the gun, and the clog was gone.
Maybe your tip is getting clogged real fast. When that happens, the gun simply doesn't shoot. The old guns, we had to take them apart every time the tip clogged. I don't know about the tip on your gun.
Your paint sprayer is probably not very high pressure, which means it would clog easily if stuff was in the paint ... and latex is thick and sticky and it gets crusty as it dries.
Suggestion: I would ask Sherwin Williams about the tip. See if they sell parts or tips at the Home Depot or Sherwin Williams.
Also you can clean the gun out with lacquer thinner. See if the lacquer thinner will pass through the gun. I would take it apart and clean everything with a toothbrush, and soak it in lacquer thinner. It might work, but the home-depot-home-owner-spray-equipment is generally not made for more than a few jobs. Especially the wagner-diaphragm-type guns.
Something else you might consider for a cedar-type picket fence. A roller. Sherwin Williams sells thick shaggy roller covers that hold a lot of paint. The little cheap roller covers can't paint a fence or anything else because they're too thin. We almost never sprayed a fence. We'd put masonite along the bottom and then just threw paint up with a roller [slap it on as the customers used to claim] >>> for cedar pickets, thin the paint with water (1 gallon water per 5 of paint) so it flows into the holes and gaps. Roll the fence, and then go back and touch up with a brush or the sprayer. A paint job on a fence always looks better the next day [unlike some things] so sometimes it's best to wait 1 day before doing the brush work.
Oct 13, 2010 | Garden
397 Ben/Sher .177 air rifle - installing repair kit problem
Crosman bought out benjamin / sheridan, and they still repair just all their pump guns. The ring sounds like a piece of a pellet, the barrels are silver soldered to the bottom tube, Not lead. Also, the repair kit should not have too many parts, you can only go so far with those guns before needing special equipment to get them apart. Get a hold of Crosman and tell them that benjamin sent you a bad part. They should fix it.
I had an old Benjamin Franklin in .22 cal, it was just a brass tube with a stock and barrel. I sent it to them, to be repaired, and I wanted the .22, because I had the 5mm and the 177. So I got it back, cost $29, New barrel, in .177, soldered on, new guts, new paint, trigger, bolt, the works.. Brand new gun. I told them I wanted the brass and I wanted the .22, They said oops, sorry. I didn't complain, nice old gun. Hope this helps.
Jul 29, 2009 | Crosman (4032)
I have a 2 cycle weed eater 31cc couple years old with no spark??
Hmmm.....This tells me that your magneto has gone bad. take apart the outer plastic casing of the trimmer and follow the spark plug cap back to where it ends. (Not far away) This piece of plastic looking thing pressed up against the flywheel (A Round wheel with several fins sticking up on it) is called the magneto undo the screws that hold it in place and install the new magneto. Make sure before you undo these screws that know where the wires that are attatched go. They are for the kill-switch, (The switch that turns off the engine) and are either attached to the magneto with the screws that hold it in, or are attached to these tiny flat metal pins with and unknown name. Hope this solves your problem, and good luck!
Jul 13, 2009 | Yard Machines Red Edger
Campbell hausfeld paint sprayer has no suction
The same thing happened to me before if the paint is too thick. Another reason was when the gun toppled over and paint went into the spring and needle in which case you will have to take it apart and clean it.
Oct 18, 2008 | Campbell Hausfeld Air Tools & Compressors
LG KG 800 slide
it is a pain to open these. 1. remove the battery & undo the 4 black screws. LG use a thread locking compound (loctite) on all the screws so they will be a **** to undo. 2.Prise the back cover off. 3. Pop apart the 2 rectangular connectors at the top of the keypad circuit board. 4. Lift the top board slightly & pop apart the ribbon/flex cable from the top board. The big silver bit comes off with the flex cable. There is a small bit of adhesive on this so be gentle. 5. undo the 6 silver screws holding the slide mechanism together & lift the slide off over the flex cable. 6. pop the 2 screw covers off the top of the phone then undo the 6 screws holding the front cover on. 7. pop the flex cable off. then the touch pad connector. then the camera lens connector. Gently pull the screen circuit board out of the front cover. Careful as sometimes the speaker is glued in place. 8. Unclip the lcd connector & gently remove the small battery looking thing (it's got red & blue wires on it) from the back of the lcd panel. It's glued on. Have fun. It took me ages to work this out.
Aug 05, 2007 | LG KG800 Cellular Phone
Not a 5000 but a 2100E ?
You may find dissasembly guides on the internet. However I don't recomand you to dissasemble your laptop unless you have some experience with these kind of things. Also, from the years of computer service I can tell you that when laptops fail it is pretty serious. Naturally they have a lot of protections and failsafe mechanisms in case of internal failure. Can you explain your problem in detail? Maybe the motherboard isn't that ..dead.
Jan 12, 2007 | BenQ Joybook 5000 Notebook
Crosman Phantom .177 Caliber Break Barrel Synthetic Stock Air Rifle Logo
392 people viewed this question
Top Crosman Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Crosman Boating Expert? Answer questions, earn points and help others
