Question about Sony Audio Players & Recorders
Sony boombox model cfs-b11 transformer
I have a sony boombox model cfs-b11. The transistor is beyond repair, and I cannot test it to find the output voltage/amperage ratio. Do you know the correct output ratio the transformer should have?Thanks.
  • 10,594 Answers
Your tape requires 9 volt transformer as shown in below schematic..
Part number is 1-450-016-11
Posted on Mar 05, 2009
Sony cfd-s01 boombox radio
Hi Bart,
You will find there is a specification plate on the rear of the unit.
It should have a rating on it showing the wattage of the unit. This is usually the amount needed to operate all the functions of the boombox.
The wattage is your input voltage multiplied by the current draw in amps. So the amperage is the rated wattage of the unit divided by the input voltage.
Usually all power goes through the transformer, so I would use this input amperage as a guide, and assuming there is no power loss, use the same calculation for the output - you know it is 9 volts, so the wattage going to the unit is the same as the input wattage, so you can calculate the amperage from this.
Transformers usually work on AC input/output, so there will also be a rectifier to convert the AC to DC for your boombox.
I would add 10 - 20% above your calculation to make sure you have sufficient power. Also I suggest that you install a fuse between your transformer and the boombox for safety.
Feb 02, 2014 | Audio Players & Recorders
Howb to test for bad tv flayback transformer
If and this depends on brand and model number, the output transistor is shorted confirm the voltage from it to the transformer and if being held down or High voltage only comes up to 5 or 6 thousand volts the flyback is suspect.
Most shops of course have a ringer which will with part out of set test the primary winding (one that goes to and from the sweep transistor).
Some models are more prone to bad transformer than others so look at the history of this brand/model.
A bad one will usually take the sweep transistor out sometimes repeatedly--but other issues in for example the driver circuit in some models will cause the transistor to pull excessive current and get hot very fast---not usually the transformer.
Aug 28, 2012 | Televison & Video
SONY MODEL KV-G14Q2S TV IS ALWAYS ON STAND BY INDICATOR AND REMOTE SENSOR INDICATOR LAMPS AND TIC-TIC SOUND GENERATES FROM CHOPPER TRANSFORMER
The SMPS sounds as if it is OK. The line output transistor has probably failed and maybe the transformer. Before leaving it as repaired, check the tuning capacitor across it and check the 135volt HT line for stability.
Hope that helps.
Feb 16, 2011 | Sony Televison & Video
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
I only need the amperage for the adapter for a CFS 914 sony radio. Thank you
The adapter is an AC-905. The important bit is the 500 mAmp. The actual part number is 169301611
Nov 20, 2010 | Sony CFS-914 Cassette Boombox
Bad transformer? Sony CFS-W338 boombox
More than likely there is a voltage resultor in the circuit that will take the 24V input and convert it to 9V internally. This voltage difference is not necesarily a problem. What is the problem with the unit that is causing you to check the voltages?
Dan
Sep 14, 2009 | Sony CFS-W338 Radio/Cassette Boombox
Sony trinitron won't power up.
usually the horizontal output is shorted due to loose connections on the transistor, driver transformer, or driver transistor. this will cause failure of 2 power transistors in the low voltage supply and open up a low ohm circuit protector. any reputable shop can repair this for a fraction of the replacement of the set. and the repair lasts.
Aug 20, 2009 | Sony Televison & Video
KV-32XBR15
Yes, you should check other parts. The horizontal output transistor is more than likely shorted. Also the flyback could have gone bad. Some SONYs have problems with the horizontal driver transformer which is connected to the base circuit of the horizontal output transistor. If this little transformer has a loose solder connection, it will take out the horizontal output transistor. This may give you some insight as to where to look for your problem. Stargazer
Jun 11, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
857 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
