Question about Lexmark X6150 All-In-One InkJet Printer
Won't power on
I haven't used my printer for about 6 months because I was out of ink. I put it in my office to use for the business and it won't power on. I have cleaned everything and made sure everything was connected. I don't know what to do and also I would like to know if the printer will power on without ink cartridges in.
  • 29 Answers
I hope you did all these checks
1. Is there power at the wall socket.
2. Is the power cable good.
3. Is the wall switch on.
4. Did you switch the printer on.
If the power on light does not come on then it is an electrical fault, and repair is likely to cost more than a new printer. A possible cause is a faulty on off switch.
All Inkjet printers must be able to power up with no cartridges, as all new printers come without cartridges installed. Some retailers install ink cartridges at the time of sale.
If you store any inkjet printer with out parking the heads properly or no ink cartridge in place. the print head will dry out, 6 months is more than long enough to do this. If this is the case then replacement is your best option,
It is possible to clean blocked heads by dissolving the ink with water and blotting the heads. DO NOT RUB as this will damage the nozzles. Access is usually difficult and usually requires that printer be taken apart.
Posted on Mar 05, 2009
Check ink cartridge on right
Yes - if they are not used they will dry up and be unusable.
Unfortunate but you need to replace them.
For future ref - IF they will not be used in 4 - 6 months
pop them out and put scotch tape on the head where ink comes out
and that should keep them good for several months..
I have done that and close to a year later - was fine.
Hope this helps :)
Sep 30, 2012 | HP Photosmart C4180 All-In-One InkJet...
Canon IP3300 won't print color
hi chette,
its a common problem for printer dye ink,have you try to use other cartridge? a brand new one maybe?
if you insist using the old one, try these step.
1. use vinegar to clean your cartridge head
2. put a little vinegar into the cartridge
3. try deep cleaning it.
it only work for dye ink base not else :D
ciaw.
Jul 11, 2012 | Canon PIXMA iP3300 Printer
Have 5400- needs new black ink. How do I get to the instructions on this
You can purchase cartridges online from www.lexmark.com. Lexmark cartridges are also available in some large office supply stores.
To replace a cartridge on your printer, please follow the steps below:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Jul 27, 2011 | Lexmark X6570 InkJet Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
On my HP Business Inkjet 1200 the black/magenta/yellow lights are flashing but not the cyan. Neither the printhead or ink cartridge light is lit. With 3 out of 4 lights lit what is the printer complaining...
You may be using non original ink catridges, the printer chip will not recognise so flashes as if needs replacing.if refills are original printer chip may need to be reset.
Feb 03, 2018 | HP Business Inkjet 1200dtn Printer
Has been setting 6 months , has new ink and paper
Ink jet printers are meant to be used regularly, at least once a week.
If it was used before you put it away for 6 months, the ink is dry on the jets.
First try the cleaning function. If you're lucky, after 2 or 3 tries it may work again, and the more you use it the better print quality will result.
Failing that, there are cleaning kits you can purchase.
They consist of a cleaning solution you can inject into a used-up cartridge.
Or better yet, you can take it to one of the places where they refill ink, and for a fee they'll get it going for you.
Apr 18, 2010 | Epson Stylus C88 InkJet Photo Printer
Massage unsupport ink on lexmark X4270
Sadly, not all inks are created equal, and even inks that are claimed "compatable" are not allways safe. My HP photo printer worked great for 2 years, then I put in a "will fit" from a name brand office supply store, the printer nozzles plugged on the second print, never to print correctly again. My replacement printer is a Kodak 5300 all in one, chosen for low ink costs/ hi-output, and I get photo-lab quality, borderless prints day after day. (I'm a photographer/artist) I have run 6 color and 5 blacks for thousands of graphics, in a period of 2 months getting ready for a showing, with maybe 1 or 2 misprints.
Nov 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X6150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
