Question about Desa International Heating & Cooling
HEATER WILL IGNITE BUT IT WILL NOT FIRE. WHEN IT DOES FIRE AND YOU PUT THE TOP ON (THE COVER) IT CONTINUES TO RUN BUT BLOWS SMOKE. NOW TODAY IT JUST IGNITES. WHAT IS CAUSING THIS PROBLEM? THANK YOU. northernlightsone@yahoo.com-BOB
    Filmmaker:
    Uploaded 5 video answers.
  • 98 Answers
Check if the helium gas is flowing
Posted on Mar 05, 2009
F2 fuse blows
You have a short some where. If you continue to put fuses in you could have a fire.
Sep 01, 2015 | 2005 Ford Freestyle
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
Remington 35 portable forced air heater parts
Top cover is shorting out the spark plug wire.
Jan 10, 2014 | Heating & Cooling
Reddish smoke
Sounds like it possibly may have frozen internally. Ice blockage and water was not circulating thru it, yet the ignitors fired and fired until it overheated and shut down. Possible that the exchangers may have been fried, that is why the funny color of smoke. Once weather is warmer and not frozen, run the pump with heater off and check for leaks. If no leaks in the heater and you can confirm water is circulating thru your system (water returning into pool thru the return lines) turn or fire up the heater and inspect/monitor its operation.
Dec 20, 2012 | Hayward H Series Pool & Spa Heater 400k...
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
Blower
something blocking the air off this is why its blowing smoke
Jan 29, 2010 | Reddy R115DT Oil Filled Utility Heater
I have a a problem with my mr. heater. When I turn it on it puffs
Not knowing what Mr Heater Model you are referring to, I would suggest you call Mr.Heater's customer service line at 800.251.0001.
They have techs that can help troubleshoot your problem.
Dec 30, 2009 | Mr. Heater Portable Buddy
Ready heater r100a blows fuel but will not ignite
the air pressure is not set correctly.take a look at the back plate very closly and check to see if you have a crack in one of the plug bosses.if you do the back plate is no good and needs to be replaced.you should also change the adjuster,spring and ball at the same time.now you need to have a gauge to check to see if air pressure is correct.you can not set it with out one.
Feb 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Won't ignite and fill the entire tube with flame, cold air, smoke
The deisel fuel hogged it up. Clean everything out and replace the wick. Deisel fuel is filthy to burn and it needs a lot of airflow.
Jan 16, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Blows smoke
Both problems soud like fuel delivery problems. Start troubleshooting fuel delivery problems by checking and getting the air pump pressure to specs.
Dec 09, 2007 | Reddy R155D Utility Heater
Heating & Cooling Logo
77 people viewed this question
Top Desa International Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Gil Shultz
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
