Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
My bissell will not let the water out
I have filled the machine with the amount of water it says and shampoo, i am using the handle to pump the water out and no water is coming out.
All its doing is sucking up and not releasing any water
  • jrails1 Mar 15, 2009
    Same problem. Distributes water using hte hand attachment but not for floor cleaning. Something appears to be clogged, but can't figure out what.
Mine did that after using it one time. I took the plastic cover off where the belt goes and it had come off some how. I put it back on and it works again.
Posted on Mar 28, 2009
The shampoo is dispensing too much shampoo, it is empty in no time
Hello There,
Is your machine use the water from the tank at all? If your machine use too much shampoo, my guess is it use less or no water at all. In this case the pump is sucking very little or nothing from the water tank and it does from the shampoo tank.
Please look the attached plumbing diagram. After you opened the unit up, you can follow the tubes and clean the system (solenoid valves but mostly the tubes those involved in the water tank circuit)
Good Luck with the repair!
Sorry, I wasn't able upload!
Sep 10, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell instruction manuals
I think you are referring to the stair/upholstery tool. Attach the hose
to the machine...turn the pump and vacuum on and use....liquid is
dispensed when you squeeze the handle on the tool..
Regards.
Dennis
Aug 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Basic how to use instructions.
1. Step on the handle releae pedal and lay the handle back.
2. Remove the tank and take it to thesink.
3. Remove the top cover cover and fill the plastic bladder with water only.
4. Replace the tank.
5. Your 'Smart Mix' (shampoo) bottle is on the operator's right in front of the machine. Remove it and fill it with Bissell shampoo.
6. Shampoo is automatically mixed with the water as you dispense it depending on how your 'Smart Mix' Knob is adjusted.
You can download your complete maual here:
http://www.bissell.com/searchresults.aspx?searchtext=1698&mode=userguides
May 20, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
I have an older model Bissell rug shampoo machine, model # 1631. I have several bottles of Bissell 5 One carpet formula to use in this machine, however I have lost the measuring bottle that tells me the...
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
Mar 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I need instructions on how to use my machine. Can you please help!
if its a bissell,go to bissel .com and request a manual sent to you.there should b a cartridge that you push a button to unlock so u can fill it with water or carpet shampoo.I fill mine half water half carpet shampoo. then u put it back on ,make sure it either clicks or snaps on.plug in and turn on,they usually have a button that turns that say wash or rinse.it depends on your machine.
Jan 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Where do i put the shampoo in my bissell proheat turbo carpet cleaner?
On these machines there is usually a small container on the back of the machine below the handle.
Pull it out and fill all the way up with the proper soap.
Goodluck
Sep 15, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Oct 20, 2008 | Bissell 9200 Upright Vacuum
How to use
first take the large tank out open the top of it and place hot water in the small round opening, than put the lid back on and set the tank firmly back in place, then take the small shampoo resivour and fill that with only genuine bissell shampoo ( if you dont it could ruin the machine !!!! ) then theres a small knob near the small tank adjust that to regular or heavy traffic if its really bad.
Sep 10, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Won't release shampoo
If your floor cleaner doesn't spray, chances are the heater unit is clogged. It is easy to fix if you have a few simple tools and are mechanically inclined.
Steps to fix:
- The heater unit is located inside the body of the machine, behind the power/heater switches. Remove 6 screws and split the case open.
- The silver metal "box" inside is the heater unit. Take note of how the hoses and wires are connected. Better yet, take a digital photo for reference.
- Remove the wires and hoses.
- Take the box to a work bench, and unscrew the 6 or 7 screws that hold on the lid. Don't lose the red washers that are found on the inside of the box that keep water from leaking out of the screw holes
- You'll see a "maze" where the water runs around to get heated up. Clear this of all debris. The inlet and/or outlet ports may also be clogged. I used an appropriate sized drill bit mounted on an electric screwdriver to carefully "drill" out the clogs. Make sure all the debris has been removed. I used an electric screwdriver because my 18v DeWalt hammer drill would have been overkill :)
- Reassemble to box
- Rewire and plumb the box according to your notes or reference photo.
- Put the machine back together.
Doing this saved me a $85 repair and took 30 minutes. My machine now works perfectly.
Sep 04, 2006 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
221 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
