Question about 2wire Computers & Internet
We have a 2wire wireless modem responding to two laptops. my wife can get on line but I cannot. is it possible that I have the wiring wrong? RJ
  • 99 Answers
You should only need one wireless router for multiple laptops, I have 1 router and I connect to the internet through my laptop, PS3, and my xbox 360 at the same time. Try going to the start menu, then to control panel and find "network and connections", you should find it pops up with a window and you should see a button that says "connect to a network" click that and see if you can find the router you are looking for. You can also right click the two computer icons (1 icon with 2 computers on top of each other) If you are not connected it will have a red "X" through it, if you are connected but there is a problem with your network (IE not connected to the internet, security settings don't match the router) you'll see a small yellow upside-down yield sign with an "!" in it. Right click and open "connect to a network", try to find the name of your router and try to connect to it, try both routers. If this doesn't fix your problem, reply to this thread with a comment that tells us what you found out while doing these steps. If you are connected to the internet you will see the two computers will be blue, probably with a blue "world" next to them (meaning you are connected to the "world" wide web. Good luck and don't forget to rate. Thank you.
Posted on Mar 06, 2009
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Oct 10, 2010 | 2wire (1000-000057-000) Modem
I had ATT DSL w/ a linksys wireless router. I was
So, both computers are on the lan segment of 2wire? How many lan ports on 2 wire? Can you do ipconfig from the command line on both computers to see what the addresses are? In most cases, the first 3 octets xxx.yyy.zzz.### should be the same. If not, then 2wire is configured for vlan and the computers are actually on different lan segments & cannot communicate with each other.
Another thing you can do to troubleshoot is to ping each other's address.
You have to first establish there is communication between the 2 systems before troubleshooting further. Otherwise, you could be wasting a lot of time.
Jun 04, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Cable and wireless question
Not possible, since the "input" to the 2WIRE modem is a 4-wire telephone-line, not an 8-wire Ethernet cable.
Instead, spend about $40 to buy a D-Link Wireless G modem, and connect its WAN port to the cable-modem, and connect up to 4 Ethernet cables to "wired" computers, and configure the "wireless" component of the D-Link router.
May 07, 2010 | Computers & Internet
T636400000 does it have an ethernet card built in the unit?
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at
Please vote.
Feb 17, 2010 | NEC Versa VXi PC Notebook
How do I get my AT&T modem to be wireless? It
does your laptop have wireless..??
find you modem model and the manual for it here. .
it probably just needs to wireless configured and enabled. .
all else fails call ATT support during the daytime in your time zone. . .
have a pen and paper ready.. .
be patient they are there to help , it whats you pay for every month.
Nov 16, 2009 | Computers & Internet
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
2 wire 2700 hg-b
The 2Wire 2700 is a residential gateway, a modem and router in-one. There is an RJ-11 jack in the back of the gateway and this is where your dsl phone cord plugs in. There are four RJ-45 jacks in the back for connecting devices using ethernet cable. As a router is can operate both wirelessly and wired. For wireless operation you'll need the WEP key which is located on the tag on the bottom of the gateway. It's the number enclosed in brackets, between the two bar codes.
Redneck Geek
Sep 09, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at
Feb 03, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
119 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
