Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Looking to replace vac belt on eureka altima bagless upright
I can't find manual nor are there any markings for plate removal...
Thanks jim nash
jnash4@nycap.rr.com
  • 328 Answers
Hi Jim You should find the cross head screws on top of the hood - look below the duster and there should be a screw there, also another screw on the other side and two either side of the main floor head.
Posted on Mar 06, 2009
  • 701 Answers
The screws to remove the base plate can be found on the bottom. You can also find a replacement belt at www.vacbelts.com.
Posted on Oct 10, 2009
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
May 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
I have a Eureka Bravo! 7.0 vaccum cleaner, how do I change the belt
Turn the vac over so the brush is facing up.. There is a cover plate that surrounds the brush.. Take the screws out and remove the cover plate.. Pull up on the side of the brush that the belt is on.. Replace the belt.. The belt goes around the metal shaft and the brush.. Push the brush back in place.. It might be a bit tough going in because the belt causes some tension.. Put the cover plate and screws back in..
Good luck ! Please don’t forget to rate well ;o)
Aug 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
My eureka bagless uno vac problem is when I use it the belt gets really hot and starts smoking
try to manually turn the brushroll. if it feels tight then u will need a new brushroll. otherwise try replacing the belt
Jul 13, 2009 | Eureka Uno 2998AZ Bagless Upright Vacuum
Looking for the instruction manual for the Eureka Altima 2993AV HEPA Upright Bagless Vacuum Cleaner
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Jul 02, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka altima 2993av bagless
Hi
Sounds like its blocked. Check under the glide plate and the hose. Look in the book for model specific details
Feb 22, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka the boss upright bagless vacuum. how do i open it to get to the belt area? the brush seems stuck. it wont move
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=801547
Generic problem for all Vacuums
Posted by sweet0nes on July 18, 2008
Eureka the boss upright bagless vacuum. How do I open it to get to the belt area? The brush seems stuck. It won’t move.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 18, 2008 | Vacuums
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
692 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
