Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
How will i restore deleted userinit file in system32 folder?
I accidently deleted userinit file from system32 folder and when the computer is restarted its not allowing me to log on , it kicks me back to the user logon screen. is there any way that i can restore this file from xp cd?? or whats the best way to fix this? i have tons of data in my computer and i reallly dont want to do a reinstallation. please help ASAP.
my operating system is XP home SP2.
    Problem Solver:
  • 14 Answers
Insert the original Windows XP CD (Windows XP with Service Pack 2 is preferred, but not required) and reboot the computer. You may need to configure your computer to boot from the CD-ROM drive.When the Windows XP Setup has started, press "R" to "repair the Windows XP installation using Recovery Console".
Select the Windows installation to repair (generally this is C:\Windows) by typing its number and then pressing ENTER.
Type the Administrator password and press ENTER.
Type the following commands:
D: [ENTER]
CD I386 [ENTER]
EXPAND USERINIT.EX_ C:\WINDOWS\SYSTEM32 [ENTER]
NOTE: If your CD-ROM drive has a different letter assigned to it, enter "X:" instead, where X is the appropriate drive letter.
After entering "EXPAND USERINIT.EX_ C:\WINDOWS\SYSTEM32" you should see the text "1 file(s) copied", in which case all went well.
Remove the Windows XP CD, type "EXIT" and press ENTER to restart your computer. You should now be able to log on as normally.
Posted on Mar 05, 2009
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
How will solved script error "c:\windows\systems32\rahul"svirusprotection.vbe"
Rahul'sVirusprotection.vbe is a virus.
Follow the given steps to get rid of it
1) In Windows Explorer
Go to Tools -- Folder Options --View
Show hidden files and folders ---check this one
Hide prorected operation system file --Uncheck this one
2) Go to System Directoty ex: (C:\windows\ system32)
find this file "Rahul'sVirusprotection.vbe" and delete this one,
if u can't do that following the below steps
1)open the TaskManager(press control+Shift+Escapte key) then in
process Tab find ths Process "wscript.exe" and delete this one
or
2) using Unlocker 1.8.8.exe (search in Google site) for delete this
file
3) Type Regedit.exe into RUN Command
HKEY_CURRENT_USER\ SOFTWARE\ MICROSOFT\ INTERNET EXPLORER\MAIN
[Window Title = ""]
[Start Page = "www.google.com"]
HKEY_LOCAL_MACHINE\SOFTWARE\ MICROSOFT\Windows NT\ CurrentVersion
\Winlogon
[Userninit = "C:WINDOWS\system32\userinit.exe"]
Dec 22, 2010 | Computers & Internet
When i start my windows a dialog box named WINDOWS HOST SCRIPT APPEARS and says some message about rahul's virus protection
Hi karthicku683,
Your computer is infected with viruses. Please use a good anti-virus software to keep your system clean.
1) Right click on the taskbar and click 'Task Manager'.
2) In the 'Process' tab find wscript.exe.
3) Right click on it and select 'End Process Tree'
4)
Go to Folder Options and check show hidden files and click OK.
5) Delete 'VirusRemoval.vbs' and 'Autorun.inf files' from all usb drives and hard drives.
6) Then go to C:\Windows\System32 and delete the file 'VirusRemoval.vbs'.
7) Next go to START>RUN and type regedit and Enter.
8) Go to HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
9) On the right side look for Shell which should have value of just explorer.exe. Delete anything at right side of explorer.exe if there is anything.
10) Under same key Winlogon also look for Userinit which should have value of C:\WINDOWS\system32\userinit.exe.
11) Delete all the **** after the comma.
12) Go to HKCU\Software\Microsoft\Internet Explorer\Main
On the right side locate Window Title and delete its value i.e. Sujin.com.np
Hope this solves your problem. If this information was helpful, please rate this solution.
Thank you for using fixya.
Arun Zac
Nov 24, 2010 | Computers & Internet
Laptop logs off when i log on. what can i do
Edit these values and type the correct path of shell :
Shell = explorer.exe
Userinit=X:\windows\system32\userinit.exe
NOTE: These files may also be deleted by spywares. You may need to extract them using Windows CD.
Steps for rectifying this problem:
Log on to a networked computer.
Run Regedit.exe
Point your cursor to HKEY_LOCAL_MACHINE
Select File > Connect Remote Registry
Type computer name (infected computer)
Navigate to the following location in registry of destination or infected computer
Edit these two values in right pane:
Shell
Userinit
Change these two values to
Shell=explorer.exe
Userinit = x:\windows\system32\userinit.exe
Exit from Registry
Restart Infected computer.
You should be able to log on to computer.
if it not work then go to back steps and just copy orwrite the file userinit.exe
Performing the above steps will resolve the issue.
Hope this helps.
Jul 07, 2010 | Dell Latitude D400 Notebook
How to solve rahul's virus protection.vbe
First
Open task manager and kill process wscript.exe.
Then
Delete VirusRemoval.vbs and Autorun.inf files from all usb drives if u have the virus in them.
Then
Go to c:\Windows\System32 and delete the file VirusRemoval.vbs. It is super hidden so first go to Folder Options and check show hidden and check boxes. Also required for the above files.
Then
go to start>run and type regedit and enter
delete anything at right side of explorer.exe if there is anything.
c:\WINDOWS\system32\userinit.exe,
Then
Feb 21, 2010 | Computers & Internet
Loading win xp gives message script file cleanvirus.vbs not found
Disable System Restore. Scan your computer with the free version of Malwarebytes' Anti-Malware.
http://malwarebytes.org/
If you don't have an Anti-Virus program, download Avast and scan.
http://www.avast.com/
If both scans don't detect anything, do this..
Ctrl-Alt-Del > Processes - End the following processes in order:
dxdlg.exe
wscript.exe
Start > Run > regedit - Open the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\ Microsoft\Windows NT\CurrentVersion\Winlogon
In the right hand pane, select Userinit and delete everything except C:\windows\system32\ userinit.exe
Make sure the processes wscript.exe and dxdlg.exe are not running.
Delete the following files
C:\Windows\System32\dxdlg.exe
C:\Windows\System32\boot.vbs
In your Windows drive, search for boot.vbs and delete all of them.
In your Windows drive, search for kinza.exe and delete all of them.
Enable System Restore.
Restart your computer.
Nov 28, 2009 | Microsoft Windows XP Professional With...
Hp paviliondv2050us wont start
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
E machine computer. starts up then it goes to the
This is caused by two files that are corrupt on your system. If you can get to another XP computer and get the following two files from the windows\system32 folder and copy them to the same location on your hard drive. The easiest way is to connect your hard drive to the other computer as a slave and copy them.
The files are: userinit.exe and wsaupdater.exe
Hope this helps
Apr 30, 2009 | E-Machines eMachines W2686 PC Desktop
Start up msg
First
Then
Delete VirusRemoval.vbs and Autorun.inf files from all usb drives.
Delete "c:\WINDOWS\system32\userinit.exe"
Then
Then
Then
Under the same key locate Start Page and delete its value i.e. http://sujin.com.np/
then go to Start Menu -> Run -> msconfig -> Startup tab -> uncheck .vbs files
Restart System
Jul 23, 2008 | Computers & Internet
Problem while starting computer
Hello..
TO remove this error messege follow these steps.
type "regedit" in run dialog box.
Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon"
There is a string value named "userinit".
The value of this key should "c:\windows\system32\userinint.exe"
Delete anything thing after this.
Now logoff and relogin or Reboot.
Jun 09, 2008 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
238 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
