Question about Maytag 24 in. MDB6100A Built-in Dishwasher
Runtime way too long
My Maytag Quiet Series 300 dishwasher runs way too long. Even on the short cycle, it runs over two hours. The regular cycle is over three hours. The water is red hot so it's not like the machine has to run long to heat the water. It has digital controls, so I can't manually advance the dial. It's totally unnecessary for a d/w to run this long, so I'm wondering if I can program it, or change a computer chip, to make it run for a reasonable time period. Our old Magic Chef dishwasher got everything just as clean in an hour. It's only two months old, and I don't want to replace it, but if I can't find a solution, I may have to. Thanks.
SOURCE: Maytag dishwasher legacy 300 quiet series
FYI... I followed Miss Midget's steps... and there it was... a piece of plastic... actually one of the end caps from the rack. Poor design if you ask me. So for all you "grinders" out there, it's an easy fix... just need the appropriate star screwdriver. It went back together easier than it did taking it apart. Thanks.
Posted on Nov 28, 2007
SOURCE: Maytag quiet series 300
hi, there is probably some small pieces in the shredder. Remove the cover in the bottom and you will probably find some pieces near the blades.
Posted on Apr 04, 2008
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Maytag dishwasher
Hi Terry, Welcome to FixYa, I am Kelly.
A few things can cause this. Most of the time it is drain related with the Air-Gap being the culprit that is restricting drain flow. If the dishwasher drain has a restriction when the pump motor shuts off the water left in the hose BEFORE the restriction gravity drains back into the dishwasher.
If you have an Air-gap Take a look at this link: http://www.ehow.com/how_6327450_clean-air-gap-dishwasher.html
- Basically you pull off the cover by lifting straight up. Unscrew the cap nut in the top, Lift out the cap NOTING the installed position as it will only install ONE way. Remove the debris under the cap and clear the passages. (Sometimes you have to remove the lower hoses and use a wire coat hanger or large plastic zip / cable tie) Reinstall / assemble everything on the Air-Gap.
- ALSO check the sink connection or garbage disposal port for obstructions. Sometimes it is easier to just remove the hose from the sink / garbage disposal connection to clear any obstructions.
- If the problem persists the blockage may be at the pump motor connection. Again remove the hose and inspect for blockage. Install the hose when your finished.
This should pretty much get you going. If after doing all of the above there is more that can but done inside the dishwasher. I think this is all you will need to do. Just respond here if your problem is persistent. I will gladly help you.
Thanks for choosing FixYa,
Kelly
Posted on Dec 01, 2010
How should I clean the Maytag Quiet Series 300 with vinegar?
just fill it with water no soap and drop in vinegar right in the water and let it run its cycle
Jan 27, 2015 | matag Maytag QuietSeries 300 Dishwasher...
Maytag Quiet Series 300 Dishwasher will only run part of wash cycle before tripping breaker?
I'm thinking dishwashers is installed in correctly. Too low causing an issue. Have a tech look at it.
Nov 17, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Foul smell coming from Maytag Quiet Series 300
Hello jscott,
It is typical nowdays for most dishwashers not to drain all water out of the bottom tub (Even where you cant see) due to siphon design and energy efficiency. Try using about a liter of vinegar and throw it on the bottom tub of the dishwasher. Let it run through a full cycle and see how that works. Has worked for me
Sep 07, 2009 | Dishwashers
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Maytag 24 in. MDB6100A Built-in Dishwasher Logo
119 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
