Question about Sharp EL-738 Scientific Calculator
EL738 -- area under the normal curve?
My financial/statistical calculator has functions to get me the mean and sigma etc. From there, it should have been easy to get to the probability (area under the normal curve left of Z).
Does this function exist on the EL738?
4 Suggested Answers
Noggin
  • 944 Answers
SOURCE: manual
here's the link for the manual; http://www.sharpusa.com/files/cal_man_EL733.pdf Check page 5 - top right - the dot is a "good battery indicator" Hope this helps :)
Posted on Sep 05, 2007
  • 7993 Answers
SOURCE: statistic calculation
Here it is
Posted on Sep 17, 2009
  • 7993 Answers
SOURCE: how to calculate to the power of
To raise a number to some power other than 2 or 3, you use the [y to the x] key. Exemple 2[y to the x] 5 = 2x2x2x2x2=32.
Hope it helps.
PS. I could not understand what you wanted with those expressions.
  • 7993 Answers
SOURCE: how do you use the statistics function to find out
Press [2ndF][MODE][1] to select single variable statistics.
  1. Enter a value and press [DATA]
  2. or enter value, press [X,Y]key, enter the frequency then press [DATA
When finished you can access the mean (xbar an X with a small horizontal bar like a minus sign on top of it.)
The xbar may be a key accessed directly if xbar symbol is on top of the key, or a [2ndF] key if xbar is written on the body of the calculator.
Posted on Feb 03, 2010
Can you please help me on how to calculate mean, median, mode, standard deviation calculation on casio fx-991ms scientific calculator
This will show you how to do statistics (calculate average, standard deviation, regressions etc.) as to the mode and median refer to the definitions.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Apr 19, 2011 | Casio FX-115ES Scientific Calculator
Hod do you put this calculator into statistical mode?
The 30XA doesn't have a statistical mode; all of the statistical functions are available at all times.
2nd [CSR] clears the statistical registers, Sigma+ adds a data point, Sigma- deletes a data point, 2nd [x-bar] gives the mean, 2nd [sigma-x-n] and 2nd [sigma-x-n-minus-one] give the population and sample standard deviation.
For full details, refer to the statistics section in the manual. If you don't have a manual, you can download a guidebook from
http://education.ti.com/educationportal/sites/US/productDetail/us_ti30xa.html?bid=6
Jan 08, 2011 | Texas Instruments TI-30XA Calculator
Can i do statistics on the casio fx-115 es? and how can i use it?
Yes and here is how to do 1-var statistics and 2-var statistics. Please read the whole post. I assume you know the theory. I will show you the key strokes
Nov 06, 2010 | Casio FX-115ES Scientific Calculator
Hello. I just wanted to ask you how do I calculate the variance and standard deviation in my cfx9850GB plus. I had a quick look at the manual but I couldnt find the info. thankz .
This shows you how to enter your data and calculate some statistical values. Keep in mind that the variance is the square of the standard deviation.
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the statistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Example: Enter the following values in List 1
1st line enter 90 [EXE]
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
When finished you press [F2:Calc], then [F1:1Var] and the statistical results appear on screen.
Title of screen : 1-Variable
x bar =74.7142857
Capital Sigma x= 523
Capita Sigma X squared = 39851
x lower case sigma n = 10.5249945
x lower case sigma n-1= 11.3682934
n = 7
Scroll down with Down arrow to access other data
minX =56
Q1=68
Med =75
Q3=85
Xbar -x lower case sigma n =64.1892911
x bar x lower case sigma n = 85.2392802
maxX=90
Mod=90
All you have to do now, is to look at the theory you learned and interpret what these values mean.
Sep 05, 2010 | Casio CFX-9850G Plus Calculator
How to calculate standard deviation
for 1-Var statistics
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
How to use graphing calculator?
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Aug 13, 2010 | Casio FX-300MS Calculator
HOW TO USE LINREG(AX +B)
The post addresses several questions
  1. 1-Var statistics and standard variations
  2. 2-Var stats (calculating the statistical values)
  3. Regressions (linear or otherwise)
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
REGRESSIONS
To use the regression a+bx,
1. Select STAT mode : [MODE][3:STat] [ENTER][2:a+bx]
2. Fill the X and Y values in the template.
3. Press [SHIFT][STAT][7:Reg]
You have several options 1:A to get coefficient A, 2: B to get coefficient B, 3:r etc.
To access each one, you have to press [SHIFT][STAT][7:Reg] anew.
To access the various sums, you press [SHIFT]{STAT][4:Sum] and you can select Signa_x, Sigma_x^2, etc..
Jul 15, 2010 | Casio FX-115ES Scientific Calculator
How do i use this calculator (casio CFX 9850)to find the variance
Part A shows you how to enter your data and calculate some statistical values. Keep in mind that the variance is the square of the standard deviation.
You can safely ignore the PART about REGRESSIONs until that time you need the information.
PART A
In the main menu select [STAT] icon to enter Stat mode and display the statistical data lists. Use the satistical data lists to input data and perform statistical calculations. Use the arrows to move the highlighting around the lists.
Exemple: Enter the following values in List 1
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
x bar =74.7142857
n = 7
minX =56
Q1=68
Med =75
Q3=85
x bar + x lower case sigma n = 85.2392802
maxX=90
Mod=90
PART B
  1. Once you enter your data [MENU][STAT],
  2. press [F1:Graph],
  3. select Gph1, Gph2, or Gph3.
  4. Once the graph of the experimental data is drawn, you will have access to the diverse regression models.
  5. Your choices are
  • [X:Linear]
  • [Med-Med],
  • [Quadratic :X^2]
  • [Cubic;X^3]
  • [Quartic: X^2].
  • Press [F6] to scroll right to access the others:
  • [Logarithmic:LOG],
  • [Exponential :EXP],
  • [Power :Pwr] and
  • [Sinusoidal:Sin]
  1. After you select a model and press [EXE], the screen displays the equation and its various coefficients.
  2. On that same screen, you have a menu option [F6:Draw].
  3. If you select it, the regression curve will be drawn on the same screen as your statistical graph.
  4. This allows you to judge if the fit is good. If it is not, you have the option to choose another model.
  5. The other option [F5:Copy] allows you to save the regression equation in the Y1, Y2, etc. variables.
Jun 02, 2010 | Casio CFX-9850G Plus Calculator
FX-9750GPlus Calculator: I want to solve the goodness of fit problem on my ...
PART A
2nd line 85 [EXE]
3 79 [EXE]
4 75 [EXE]
5 70 [EXE]
6 68 [EXE]
7 56 [EXE]
x bar =74.7142857
n = 7
minX =56
Q1=68
Med =75
Q3=85
maxX=90
Mod=90
PART B
  5. Your choices are
  • [X:Linear]
  • [Med-Med],
  • [Quadratic :X^2]
  • [Cubic;X^3]
  • [Quartic: X^2].
  • [Power :Pwr] and
  • [Sinusoidal:Sin]
May 16, 2010 | Casio FX-9750GPlus Calculator
Standard Deviation
If you want to do statistics with this calculator you press [MODE][3:STAT]. You have then 8 options 1:1-var, 2:A+BX, etc.
For one variable statistics you press 1. Enter the values for the X variable in the template. Once finished you press [SHIFT][1](STAT) then select the value you want ( n, x bar , and the standard deviations (X sigma n) and (X sigma n-1).
Hope it helps.
Jul 30, 2009 | Casio fx-300ES Calculator
Sharp EL-738 Scientific Calculator Logo
57 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
