Question about Maytag MMC5000 Microwave Oven
I have a Whirlpool MH6130XEQ-0 microwave that doesn't heat food. Everything else works fine, turntable, clock, timer, fan. It sounds normal but doesn't heat up anything. Please Help
  • Maytag Master
  • 9,086 Answers
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
I have a Whirlpool MH6130XEQ-0 microwave that does - d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
If within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), the manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a Whirlpool-authorized servicer.
You can find your nearest Whirlpool/Maytag-authorized servicer here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Mar 06, 2009
My Whirlpool microwave model MH6130XEB-1 made a pop noise and now will no longer heat food. Everything else works fine, clock, timer, fan, turn table, etc. Is this a fuse problem?
It can be the fuse supplying the magnetron, or the magnetron itself which has failed. Another suspect is the high voltage capacitor in this circuit.
Don't try to fix this yourself as the internals of a microwave are dangerous, with high voltages even when unplugged.
Aug 27, 2013 | Microwave Ovens
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
Aug 18, 2009 | Whirlpool MH1150XM Convection/Microwave...
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Maytag MMC5000 Microwave Oven Logo
878 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
