Question about Brother IntelliFax-2820 Laser Fax
Brother fax machine says back cover open and it is not open. Why?
  • superadmin Mar 13, 2009
    My Brother Intellifax 2820 keeps telling me the back cover is open but it's NOT! I've turned it off. I've open and closed the back cover. I've opend and closed anything that will open and close but NOTHING will satsify it! Ideas?!
  • jjeeeennn Apr 08, 2009
    I can not get the jammed paper out of the back.
    And it keeps saying that the back cover needs to be closed.
This message comes up sometimes when paper is jammed inside. Remove paper thru back cover.
Posted on Mar 19, 2009
2 Suggested Answers
djrecklezz
  • 57 Answers
SOURCE: My fax machine is saying cover open when the cover is closed
unplug it and leave it unplugged for a minute then plug it back in and turn it on
Posted on Jan 06, 2009
Back cover open message although cover is closed
Open the top and back covers. If you see any jammed paper or
other item, gently pull it out, then close the covers. If the error message
remains, open and close the covers again. If the FAX/MFC cannot reset
itself and return to the date and time prompt, it will display MACHINE
ERROR XX. Please call Brother Customer Service
and tell them the Machine Error number at:
In USA:
1-800-284-4329
In Canada:
1-800-853-6660
In Montreal:
1-514-685-6464
Jan 15, 2011 | Brother IntelliFax-2820 Laser Fax
Back Cover Open Close The Back Cover Is Message I'm getting. What is the Problem?
Open the front cover and remove the drum and toner(cartridge).
There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
May 31, 2010 | Brother IntelliFax-2820 Laser Fax
Fax display says, close back cover even with back cover closed.
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-4100e Fax Reset drum counter
With the front cover still open, you should press Clear ("Replace Drum?" should appear on the display), and then 1 for Yes. Wait for "Accepted" message and close cover.
It may be necessary to remove the drum unit and put it back in, and then, with the cover open, do the a/m procedure.
Nov 07, 2009 | Brother IntelliFax-4100e Fax
The brother fax 2820 keeps signaling to me to close the back cover no covers are open
Open that back cover, and you'll see another, black plastic plate that also can be pulled to swing down. Running across that plate is a skinny black rod. At the right-hand end (when you're peering in the back of the machine) it has a couple of right-angle bends, ending in a vane that should swing through a curved slot in the side wall inside the machine. That vane interrupts a sensor to tell the machine that the door is open or that paper is jammed in the back. Sometimes it gets bent with the vane outside the curved slot. Gently bend it enough to drop it into the slot, close everything up, and try it out.
May 13, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC-7220 says close back cover but it's already closed
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine broken need to forward to different fax
HELLO! OPEN THE BACK DOOR AND CHECK IF THE SENSOR FELL OUT, IF YES PLEASE SNAP IT BACK IN WITH OUT BREAKING IT
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Drum problems
After reinstall the new drum unit, keeping the front cover open.
Press Clear/Back.
Press 1 and when the LCD shows
Accepted, and close the front
cover.
Jul 17, 2008 | Brother MFC-8220 Fax
Brother IntelliFax-2820 Laser Fax Logo
2,189 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
