Question about MGE UPS Pulsar EX15 Rack (89015R) UPS System
Need replacement battery for a Pulsar EX15
What battery do you recommend?
    Filmmaker:
    Uploaded 5 video answers.
  • 98 Answers
I reccomend LED bateries as they last longer and are very sufficient
Posted on Mar 05, 2009
My mother has a fifteen year old Pulsar Y480-5730 that doesn't run anymore. Any recommendations?
Did you check the watch battery? Pulsar watches run a long time! If a new battery does not start it up you can take a can of air and just squirt a little in the area where the battery goes (very gently) to blow out any dirt then install the battery and put back on. If it is still not working you need to take it to your local jewelry store to have an estimate for repair, usually 60.00 to 80.00. I hope this helps!
Sep 18, 2011 | Pulsar Watches
I have a Pulsar Solar Watch that seems to need a new battery. Where can I get a new battery and should I replace it myself?
This is a complicated repair, not just a battery exchange. Go to a watchmaker. Probably 40 bucks
May 20, 2011 | Pulsar Watches
I have an UPS MGE Pulsar EX30. One batterie was with zero volts. The others are with 13 Volts. I changed the bad batterie, but when I connect the batteries, I get a spark like as in short circuit. I don't...
make sure the UPS is off when you connect the battery and make sure the polarity is correct. Look for the signs on the casing. Check the other batteries to see if they are connected in serial or parallel. Should be in series if it is a mains voltage UPS from 12v batteries so the negative of one goes to the positive of another and they daisy-chain together
Nov 05, 2017 | MGE UPS Pulsar EX15 Rack (89015R) UPS...
Purchased a new pulsar chrono as a gift, the battery was dead, since found out low charge batteries are placed in new watches to check functions but they recommend the battery be change. Problem is,...
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
Dec 26, 2009 | Pulsar Watches
NO VOLTS OUT
hello
As you have mentioned that the light are glowing shows that it is not a hardware circuitry problem.
I think that you have to check the battery of the UPS and replace it if needed..
To me it doesn't seems like a circuitry problem.
Thank you
Aug 17, 2009 | MGE UPS Pulsar EX15 Rack (89015R) UPS...
I work for the STATE Dept I have a unit Without the External battery pack. I get NO AC Volts out of the plugs in the rear ??????
It is a little obvious but I have to say it. Make sure the wall outlet it is plugged into is live and the UPS' power button is on. Now for the (slightly) less obvious:
The battery is dead. Even high-end UPS batteries are only good for 3-5 years depending on your evironment and the UPS' sensitivity level. I budged for battery replacement every 5-years whether they die or not. Better safe than sorry.
Finally, the UPS hardware is dead. It does happen. I have seen them die after only a couple of years. Overheating is usually the culprit.
If this doesn't narrow it down pick up the phone and get the manufacturer on the line. Make sure you have your model and serial number ready because they will ask.
If this helps please vote for my solution.
Mge pulsar 3000 does not power up
MGE Pulsar 3000 is an online UPS. try to check the battery first if its ok. coz for an online UPS it will need to have a good working UPS battery to trigger the switching relays to on the online UPS unlike backups UPS that can be turn on without any batteries
Aug 13, 2009 | MGE UPS Pulsar Evolution 3000 UPS System
Need to replace battery
Take the watch to a jewlers, let him replace the battery they usually only charge for the new battery,
and they do not cost much.
Nov 12, 2008 | Pulsar PXF182X Wrist Watch
MGE UPS Pulsar EX15 Rack (89015R) UPS System Logo
147 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
