Question about Xerox WorkCentre M15i Laser Printer
The Automatic Document Feeder (ADF) is not working.
I am trying to fax and copy with the Automatic Document Feeder (ADF). Its plugged in the back and when you insert the papers you hear a click, and nothing happens. What am I doing wrong or what do I have to change?
  • 3 Answers
A little help here, what machine are we talking about. Do you here any thing moving?
Richard Eklund
Posted on Mar 05, 2009
When I try to make copies using the ADF the screen tells me to remove documents and place on glass.Can you explain why. I have sveral pages
Automatic document feeder requires you to insert files into holder and let the machine scan through the pile providing you have not over ridden settings to sounds as if you have switched off adf to manual which would require you to place each document onto glass one at a time.see if you can switch it back to auto in the screen menu.
May 04, 2015 | Epson WorkForce WF-2530 All-in-One...
Need instructions for sending a 10 page fax. I do not have a GETTING STARTED GUIDE. Is there a way to download a copy of the GUIDE? OR will you provide help?
Dear Joan
since the model was not mentioned its difficult to say but in most cases the fax is having a ADF (automatic document feeder). Few of then scan the face downward and other face upward.
test yourself by putting the document at ADF face upward and copy it, if copy comes as original, then put all 10 pages face upward in the ADF. press OHD(on hook dial) or SPK PHONE, dial the fax no. get the the fax Rx tone press START. Also you you can dial the fax no. and press start from memory.(as it will scan to memory and then fax).
Mar 17, 2015 | Office Equipment & Supplies
Xerox documate 752
Your document must be in place/position to be scanned, faxed, etc.
Place document, then scan. ADF is your automatic document feeder. Used when copying/scanning multiple pages. Reload and try again.
Aug 29, 2013 | Sewing Machines
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
Just trying to make some copies...the display on the printer says
The ADF is the "automatic Document Feeder" it thinks something is in there when there isn't. check to see if something is stuck in it that would cause it to "think" that.
Jun 24, 2012 | Canon Pixma MX410 All-In-One Printer
Cannot print screen shows ADF.what does this mean?
ADF stands for Automatic Document Feeder and it means the device mounted on top of your pixma that allows multiple pages to be scanned/copied/faxed one at a time automatically.
Now why does it not print? The machine "believes" some document is inserted in the ADF in order to be scanned/copied/faxed, and wants that operation to be completed before it accept any print job. Please remove, if present, any paper from the ADF. Maybe its only some small piece of broken paper or even dust on the sensor in the ADF.
Aug 08, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Xerox WorkCentre M15i Laser Printer Logo
173 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
