Question about Samsung WEP200 Headset
I cannot get it to pair with my Samsung Sway...will not recognize device.
I had this problem too when you hold down the button ON the bluetooth ...hold untill the blue light stays lit ..I would hold down till the blue light flashes but hold down until its fully lit...then it will read and pair to your phone...GOOD LUCK = )
Posted on Mar 19, 2009
How do I connect my samsung sghA847 to my bluetooth?
try to pair your devices following the instructions
Aug 12, 2014 | Samsung SGH Cell Phones
How do I pair a Samsung bluetooth headset model HM1000 to my Nokia C7-00 phone?
1.first on samsung bluetooth device
2.press& hold call answer button in bluetooth device now light is on ,not blinking
3.and then search your bluetooth device by your phone and pair.
Apr 11, 2012 | Samsung HM1000 Bluetooth Headset
Em227 wont pair with samsung intensity... phone will recognize but continually get failed pairing message... please help!
make sure that the code you enter in to the phone as the pairing code is correct. most of them are 0000 or 00000, some of the samsungs are 1234.
this code must be entered in correctly to pair the device. If you are using an iphone, there are some issues with it people report.
Aug 24, 2011 | Southern Telecom Emerson Bluetooth Headset...
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
Samsung WEP 450 was working ok for its 1st 24 hrs paired with Samsung B2100, however will not connect now. I've gone through the pairing up process again and the device cannot be found. The only other...
normally, the pairing has to be done once. If successfull, you can not pair the device a 2nd time withou removing it from the "paired devices" list in your phone. In order to get it recognized you should do the following.
1. check that BT is off on both devices
2. turn BT on on your mobile phone
3. power on your headset. In case, you have paired the headset successfully before, it has to be registered in your phone. It should then automatically find for the paired device (your phone in this case) and connect.
Dont try to power on the headset before turning BT on on your mobile phone.
If you have no success try to navigate to the bluetooth settings, check "paired devices" and make sure that your headset is deleted. Do the pairing and the 3 stepps above once again.
Don forget, that the headsets also have to be charged..
Jan 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
Samsung sgh-t139, Bluetooth won't recognize my laptop
Open bluetooth software, open add device, make sure phone is set to visible, then search devices, pairing code should be 0000
Jun 02, 2010 | Samsung Cell Phones
My samsung doesnt recognize anyother divice or the divices cant recognize the samsung, so i cant transfer any files via bluetooth.
It is not possible from my experience (I have one and I have tried everything). The Bluetooth on this phone is only for connecting a headset, nothing else. It paired with my Jawbone set quite fine. You want to share photos...you are forced to use the T-Mobile service....
Oct 14, 2009 | Samsung SGH-t239 Cell Phone
I just got a Samsung LG CU400 and when I went to pair my BT4051 with it it does not recognize and bluetooth device even though the headset is on
you have to make sure that you set the phone to discovery mode for the blue tooth to recognize it
Oct 04, 2009 | Cell Phones
Samsung WEP200 Headset Logo
195 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
