Question about Braun Activator 8595 Electric Shaver
The shaver at times makes a whirring sound and doesn't cut properly.
  • Anonymous Mar 25, 2009
    I have the same problem. The cutter block is somehow failing to engage properly with the moving part (the central strip) of the "foil". If you look closely this part of the foil stops moving when it makes the whirring sound. I've played about but can't fix it myself. Very annoying!
I had same problem, replaced Motor Drive (sold by shaveroutlet.com) once I learned how to open shaver:
at the bottom, remove the plastic 'cap' that surrounds where the cord plugs into shaver by gently prying it off with a small screwdriver or similar object. once removed, the side grips just pull off which reveals 4 screws. remove screws and shaver will seperate into 2 halves and 'guts' simply plug into place. Reassemble in reverse.
Hope it fixes your problem.
Posted on Apr 03, 2009
When i step on the foot it makes a buzzing sound but doesn't do anything mbut if i turn it manually uit works.and its reading likr its good on the display.
Is the sound a buzz or a whirring sound? If it is whirring, your belt is broke, take it in and have it replaced. You might has well have it serviced at the same time (clean, oil and adjust)
Apr 14, 2013 | Sewing Machines
Tip
How to use an electric shaver
If you are a using an electric shaver for the first time, I hope that this article will get you going. Proper techniques will ensure the best, closest shave possible. Maintaining the razor by properly cleaning and recharging it will also ensure that the razor works correctly and does not malfunction during use. Proper care and maintenance of the electric razor will also ensure that the razor will last for years to come. Consider this article as a shaving-best-practices template for your first electric shaver.<br /> <br /> Firstly, clean your face and dry it. Electric shavers do a better job when your face is clean. Turn the electric razor on and begin shaving against the direction of hair growth, moving the shaving head linearly and in circles. Circular motion Stretch the skin with your other hand to make the hair stand up straighter so the razor blades shave closer.<br /> <br /> After shaving, turn it off and rinse the cutting heads under warm water. You can also use jet clean system once a week to clean your shaver. Make sure that you charge it for the time specified in user manual. Overcharging may cause damage to the battery.
on Mar 03, 2011 | Health & Beauty
Singer 2662 Needle doesn't move
when was the last time the machine was serviced?
Apr 11, 2012 | Sewing Machines
What's your problem?I
Batteries for your shaver are 1.2V. If you have instaled it properly with good solder connections it sounds like there may be a problem with the board
Nov 10, 2011 | Health & Beauty
Ref. Braun shaver (mod. 5567 -"universal"). Just changed the batteries after 20 yrs. of use. The motor is really powerful, now. The shaver, however, does not want to cut my whiskers now. It...
Based on the information you provided, it sounds like the shaver is working as it should. If the hair you are attempting to shaver is longer than 1 days growth, you will need to trim it down to stubble length for the shaver to be able to cut it properly
Jul 12, 2017 | Braun Health & Beauty
I have an xvs 1100 custom 54 plate. Recently having problems starting it up, eventually it does fire but only after holding the ignition down for 10+ secs, it makes a whirring sound as though it...
If it normally fired up straight away, and now when you hold it down and release it only makes a whirring sound. Sounds like your starter clutch has failed.
There are little signs when this happens. Often after a successful start you will hear a small whrring sound, or you will go to start it and it will catch then release to a whirring sound.
Aug 02, 2011 | 2003 Yamaha V Star 1100 Classic
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Hand jig saw stops cutting - makes whirring noise - then restarts
Jig saws are not made to cut through aluiminum espescially that size. That is really thick and it sounds like you have worn out the motor trying to cut it. If the saws are hot. Let them cool down then proceed but like I metioned before you are putting a lot of stress on something not made to cut aluminum even with a metal cutting blade
May 21, 2009 | Saws
Wahl 9765-301
if you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Jan 30, 2008 | Wahl 9765-301
Braun Activator 8595 Electric Shaver Logo
252 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
