Question about HP Photosmart C5180 All-In-One InkJet Printer
I am trying to print 4 x 6 photos, and have set all of the settings to 4 x6, but I the printer keeps printing part of the photo on the entire 4 x 6 area of the paper. Could you help please!!! Thank you.
    New Friend:
  • 52 Answers
I belive you are saying the printer is trying to print say an 8X10 picture on you 4x6 paper. If this is the case, the software is not being set correctly for the size of paper.
Posted on Mar 05, 2009
Only printing 1/2 the image of the selected photo, I have tried changing the printer cartridge but still only prints 1/2 the selected image, any ideas why this is happening?
I am not familiar with that particular printer, but it could be as simple as making sure you have the entire picture selected..but it sounds more like the cartridge is either clogged or there is a setting that needs changed...try aligning the cartridge(s) and printing a test page. (that part is usually under a maintenance or troubleshooting type section) if that turns out fine, then there may be a setting thats off...look at your print settings...you may have a separate section just for printing photos...even if you don't, look at your page setup.. look specifically at the margin settings...that might be where the problem lies..you can always play with the margin settings- i would recommend saving them under a custom setting if you want to keep them, instead of default though...that way you have your regular settings for general printing... and do a "print preview"...that might be a good idea anyway, so you wont have to waste ink and paper trying to get your stuff to turn out how you want it (plus that will show you if margins are set right)...for that, there should be a checkmark box you can select to always do print previews...
also, look to see if you have a selection or checkmark box that says "fit to page" or where you can select how many copies you can print per page..this can be used for everyday printing, as well as for photos...
you may even see a spot where you can select the size of photo to print...usually you can pick to print "wallet size or 4x6, ete." and how many to print on a single page...maybe even multiple sizes per page...these are several options for you to look at...hope it helps :)
Jul 30, 2015 | Samsung SPP-2040 Digital Photo Printer...
Using Lex. 4'x6" paper, my 901 is not
To properly lay the 4 X 6 in paper in the tray, please follow the steps below:
  • Pull tray completely out of the printer.
  • Move the paper guides to the sides of tray.
  • Use the photo paper outline on the bottom of the tray to help you position your paper.
  • Load your paper.
  • Adjust the paper guides to rest gently against the left, right, and bottom edges of the photo paper.
  • Insert the tray.
Make sure the correct print setting is configured before printing your file. With your file open, click File > Print > Properties > From the Paper Size list of the Print Setup tab, select 4 X 6 in. Click OK to save the setting. Click OK again to print your file.
Jul 24, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
When Im using my printer only 1/4 of page [prints,I need to have entire page printed,of photo 8.5x11
check your printer setting in your computer click the start button and go to printer and faxes click there and go to your default printer right click their and chose printing preferences then go on features you can set printing option A4 size
Oct 17, 2010 | Office Equipment & Supplies
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
My mfc 495cw printer isnt printing photos
Check the printer settings on your computer.If you print a photo on photo paper you have to select photo paper on the printer media type settings.
Dec 05, 2009 | Brother Office Equipment & Supplies
I have 4 x6 printer paper and the printer only shows standard 81/2 by 11
If you use windows photo gallery to print, it will allow you to set the paper size and type, otherwise in your control panel/printers and printing preferences you can set the 4x6 paper size.
Oct 02, 2009 | Canon i860 InkJet Photo Printer
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I 560--photo printing on 4"x6" paper
You should be able to do this in print preferences. Open up your general printer box by clicking on Print. Select print preferences then page setup then select page size and a list of sizes will appear just select 4x6 and then paper type, press print and you have done it.
You might be able to get a manual from the Canon website or 'google' for the one you want.
Please remember to rate this solution.
Nov 05, 2008 | Canon BubbleJet i560 InkJet Printer
Printing photos
That is called pixelation and is usually the result of enlarging a photo, whether it be resized larger on the computer or printed at a larger size than it's original pixel dimensions.
Check your printer settings for a setting like "resize photo to fit paper" and uncheck it. Or print from a photo that is larger than the paper and it will reduce the size without any pixelation.
With digital photos you can always go smaller than the original, but rarely ever larger.
Feb 17, 2008 | Epson CX8400 All-In-One InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
141 people viewed this question
Seeker5211
Seeker5211
