Question about Hansgrohe Thermo II Rough-In Valve Chrome 06623000
Adjusting water temp
Have a Hansgrohe Thermobalance II Cross handle. Is there a way to increase the highest water temp.? At the current max. setting it is not hot enough
  • 659 Answers
Behind the handle there is usually a scald gaurd on the newer faucets. You can adjust it from there. If your not sure, follow this link and download the installation instructions to your faucet. There you will find how to adjust it step by step. http://www.hansgrohe-usa.com/us_en
Posted on Mar 20, 2009
How do you increase the water temp?
Hi Donna:
The temperature is pre-set and is intended to be not too hot to inadvertently burn someone. Increasing the setting can cause a real SAFETY HAZARD, especially if small children or seniors are involved.
With that in mind, there will be a panel that unscrews from the side of the heater. After removing it, lift the insulation back and a dial should be visible. There will be numbers, and a pointer with a screw slot in the centre. Turning the pointer to a higher number will increase the temperature.
If you are going to adjust it, only do so a very small amount at one time, until you reach the desired temperature.
Remember, increasing the temperature will not give you more hot water, it will only give you hotter water. If you need more hot water, consider getting a larger tank or an "on demand" gas fired unit.
STAY SAFE!
Jan 12, 2016 | Water Water Heaters
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
Is it possible to lower the top temperature on the thermostate. I can change the lower temp but not the max which I wish to set below the 180 level. Thanks
there is a high and a low limit on these units, the two control knobs are actually the reverse of what you are trying to accomblish,first lower the bottom or low cut off temp first then the high temp ,it must cycle a couple times for it to adjust
Jun 06, 2011 | Honeywell L4103A1019 combination aquastat....
How to reinstall heating elements. not sure about the wiring.
The electrical specifications are based on 220 volts. It should be noted that higher voltage will increase power, just as lower voltage will have the reverse effect. The (POWER MODE CONTROL) can be adjusted to compensate allowing the user to increase or decrease water temperature. For best performance adjust temperature at MEDIUM FLOW (approximately 1 GPM) this is the average water flow at any faucet with an aerator.
Remember, that any adjustments made on your unit will take seconds to reach point of use. DO NOT OVER HEAT WATER. Water temperature from 105F to 120F is adequate for all practical purposes
MODELS Model Max KW at 220V Volts Max Amps at 220V N-120 11.8KW 220V 54 N-100 10.8KW 220V 49 N-85 8.5KW 220V 38 N-75 7.5KW 220V 34 N-64 6.4KW 220V 29 N-42 4.2KW 220V 19 N-10 3.2KW 110V 29*
Nov 13, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Rinnai Infinity 26 hot water system set to 55 degrees with remote temp adjuster. Water only luke warm for showers. Burnner working, water & gas pressure ok. Any thoughts ... Stephen
If you aren't getting any error codes, then the heater is probably doing its job. Your problem is probably somewhere in your plumbing system. The most common reason you get this sort of problem is due to cold water mixing in the hot water system. There are a number of causes for a "cross connection" :
-Faulty check valve
-Missing check valve on reciculation return line
-Faulty shower cartridge
-Thermostatic mixing valve set too low
-Faulty thermostatic mixing valve
-Faulty anti-scald valve
The easiest way to confirm a cross connection is to: 1) shutoff the cold water entering the tankless heater 2) open hot water valves around the house. If you still have water flowing at your hot water fixtures, then you have a cross connection.
Jul 09, 2010 | Rinnai Digital Remote Water Heater Control...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I cant adjust water temp 0n a single handle kohler shower valve
4yrs isn't very long, but I do believe the mixer needs a new cartridge in it. unless you have a loose knob/handle.But I don't thnk so. The temps should change almost immediatley. Have someone change the cartridge. It may need a special tool. If you think you can, do it yourself, the tool comes with full instructions. Make sure it does, consult with the pkumbing person .
Nov 09, 2009 | Water Heaters
The max temp in the control is 120F. How can I
gas pressure may be increased but most boilers are designed to a limited output 24 28 30 etc
Oct 08, 2009 | Rheem EcoSense by 7.4 GPM Outdoor...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Hansgrohe Thermo II Rough-In Valve Chrome 06623000 Logo
411 people viewed this question
Top Hansgrohe Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Hansgrohe Water Heater Expert? Answer questions, earn points and help others
