Question about HP Officejet Pro L7680 All-In-One Printer
Paper jam I have a paper jam in my printer. I can't find the manual and the last time I tried to fix it by just pulling the paper out. I ended up having to by a new printer. I'm visually impaired and I'm having trouble figuring out how to get the paper out without messing up my printer. Is there somewhere that I can find a picture that shows me how to release the paper without breaking it. Thanks, Holly
    Sergeant:
  • 320 Answers
In the back of the printer there is a access door which can be easily opened manually.as that door gets opened remove the paper easily.this will help.
Posted on Mar 05, 2009
Fix paper jam on Canon E600
Managed to fix a paper jam on Canon E600 - when the paper could not be pulled out manually at all because most part of it was in side. So at the end, i figured out that - by pushing the cartridge to the end of the right side of the printer, it will start to roll the jammed paper out. And of course that was done while the printer was turned off.
Dec 27, 2012 | Office Equipment & Supplies
Ink ribbon was chewed up in my son snap lab and resulted in paper jam. I cleared the jam and repaired the ink ribbon and it still is reading that error. How can I fix this?
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
You must open up the front where the roll goes. Lay the printer back, and look up top where the paper ejects. you should see some of the paper in the feed. Pull that out with a tweezers.
Beware. I sent my printer to Sony and they tried to get me for a new cutter and thermal head. Close to $500. I then realized the problem because it happened on another unit I own. I told them to ship it back unrepaired and I fixed it myself.
Hope this helps
Jan 14, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Printer is saying paper jam and I have cleared out all paper and clippings that were stuck how can I get it to stop saying paper jam?
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink. Even if its not finished. They give you extra. And clear out all the paper from the cutter traay before you move the printer.
Hope this helps
Oct 19, 2010 | Sony SnapLab UP-CR10L Digital Photo...
IBM 1332 printer error #241 Paper jam
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
  • Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
Printer reports that it needs to be aligned. However when I follow instructions to do so it doesn't fix the problem. The printer will print on a slight angle and then the paper jams when it gets to the end...
You seem to have a paper feeder problem, or the paper adjustments in the input paper tray are not set properly, if they are try cleaning all the feed and drive rollers you can get at. Try different paper.
Dec 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Ran out of paper, tried to print four files and now the printer is completely locked up. All four top lights are on (Toner, Paper, Drum,. and Ready). The printer does nothing after going through every...
  1. Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  2. Step 2 Turn off the printer.
  3. Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  4. Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  6. Step 6 266_a1.jpg If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. Step 7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  8. Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 26, 2009 | Brother HL-2070N Laser Printer
Dell 1710 Paper Jammed in Printer
I am afraid not, you need to grab what you can as firmly as you can and try to work it out. it may help to remove the printer drum
http://uanlink.auditor.state.oh.us/pdf/uan_win_software/Dell1710LaserPrinterHardwareQuickTips.pdf
Sep 11, 2009 | Dell 1710n Laser Printer
There is paper jammed in the printer - I can see it when I look through the paper tray but cannot reach it to try and pull it through. does the paper tray come out?
paper tary should come out not for sure, I have a Brothers HL-2140 when my printer get a paper jam I have to remove the toner cart, to get the paper out then press the start botton for it to print, Hope this helps you some
Jul 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jam on 1 side
at start paper jumps in gear pulls to one side
Sep 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP Officejet Pro L7680 All-In-One Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
