Question about Lands Phones
User guide for toshiba dkt2020-sd
I need to find a user guide for a toshiba dkt2020-sd. We have the voicemail system manual but need a basic user guide for the phone. We have been unable to mute the phone for online conferences.
  • egreenberg Mar 31, 2009
    I'm having trouble setting up the voicemail function.
SOURCE: Change name display on Toshiba DKT2020-SD
Press "intercom" button, then #621. Use * to move the cursor all the way to the left. Use the # sign to change from numbers to Alpha. For example: You want "N", but the "M" comes up. Press the "0" to toggle to additional letters on same number key. For a SPACE, use the number 1 and toggle to get a space.
Posted on Feb 01, 2010
  • 6 Answers
SOURCE: DKT2020 Conference Call
1) Make your first call. 2) Press the cnf/trn button. 3) Press one of your open line buttons on the right. 4) Dial europe number. 5) Let it ring a couple of times then press the cnf/trn button again. Remember your carrier or your phone system might have international calls blocked.
Posted on Aug 20, 2007
jncayo
  • 31 Answers
SOURCE: How do you mute a conference call?
to mute while you are on a conference call, the has to be on speaker then push the mic buttonto turn it off.
Posted on Oct 11, 2008
SOURCE: Change Time on LCD for Toshiba DKT2020
Hello:
I had the same problem Yesterday.
The way uoi change it, is you have to find the phone with the lowest extension, either 0, 10, 100, 200 etc....
Once you find that phone, leave the handset on the base.
Press Intercome, you should hear the speakerhone activate.
Press #,652
You will see it say ENTER TIME
It's on a 24 hour clock. HHMMSS Format, so it it is 2:05P.M., you would time 1405XX (XX means seconds, obviously not at critical as the touror minute.
Then press REDIAL to submit the change.
Posted on Nov 04, 2008
  • 38 Answers
SOURCE: Toshiba DKT2020-SD phone how do i change the voicemail password
need to reset the voice message password from provider.
if from Toshiba kindls contact their service team
if from 3rd party voice message kindly contact the supplier
Posted on Feb 27, 2009
How do we re-set a voicemail on Toshiba DKT2020-SD?
Here is a link that pretty much explains it. However, it says to dial 400 to get to your voicemail system. This can vary in programming. If you have an auto attendant that answers your inbound calls, just dial 999 to get to the Administrator mailbox, and then follow the rest of the directions.
http://www.telelinkcom.com/quickstart_pdf/ToshibaVoiceMailSystems/StratagyVoicemailAdminMailbox.pdf
Oct 19, 2016 | Toshiba DKT-2020-SD telephone
I have a Toshiba phone (DKT2020-SD) and would like to obtain an owners manual.
While there are User Manuals for this product, it really depends what System it is attached to. Here is a guide http://www.atsco.info/downloads/CTX%20DKT-IP%20Handset%20User%20Guide.pdf
Nov 09, 2009 | Toshiba DKT-2020 Corded Phone
Our company has produced Auto Attendant messages for a client's phone system [Toshiba DKT2020-SD] and need step-by step directions for loading them. The client has not been able to provide these...
You would have to dial your voicemail extension. Usually this extension is 850 or 555. Once greeting starts you need to press *. It will then ask you for the user ID and password. User ID should be 990 and password should be 990997. Once in the mailbox you will have to follow the instructions on entering in your message. Below is a site with Toshiba manuals that may help.
http://www.wedophones.com/ToshibaManualsLead.htm
Nov 03, 2009 | Toshiba DKT2020SD Phone
How do I set a release button for a Toshiba DKT2020-SD?
This is done in program 39 in the system programming. It must be performed on ext 205 or port 005. Your manual can be found here.
http://guides.idacomusa.com/
Aug 18, 2009 | Toshiba DKT-2020 Corded Phone
Toshiba Strata DK16 e & DKT2020-SD
You did not say what kind of voicemail you have but since you have a DK16e I'll assume it is a Stratagy. The Company Greeting is usually split between mailboxes 990 and 991. MB 990 is the introduction ( Thank you for calling ABC Company) and MB 991 are the instructions ( If you know your parties extension please enter it now .... ). The Admin mailbox to set this up is 999 if you have three digit extension numbers and the default password is 999997#. If this password has been changed then you will have to get a local Toshiba dealer to help you as the password will have to be reset via a computer connected to the maintenance port of the voicemail. If you have a computer already set up to program the voicemail then that is where you will also take care of the Directory issues. If you go to www.wedophones.com and click on manuals, scroll down to Toshiba, click on Toshiba, then scroll down until you see Stratagy Voicemail you will find your Admin Guide, Good Luck and let me know how you make out or if I can help ......mitelmike
Nov 18, 2008 | Lands Phones
NEED TO CHANGE TIME
On the main phone (ext 200 or 10) dial intercom #652 and enter HHMMSS then press redial. Your manuals and guides are here
Jun 25, 2008 | Toshiba DKT2020SD Phone
Voicemail
Dial 600 from your phone. When prompted for your security code your extension number followed by 997#
you will be guided from there
May 30, 2008 | Toshiba DKT-2020 Corded Phone
Voicemail Reset Toshiba DKT2020
you need to log in to your voice mail. when you hear your voice press * , enter your user id, enter your security code then follow the prompt.
Apr 04, 2008 | Toshiba DKT-2020 Corded Phone
Toshiba DKT 2020-SD without a manual!
The phone you have DKT2020-SD can be used on many different Toshiba phone systems. For a phone all you will find are user guides. You need to find out which phone system you have and look for the manual for the system. All the Toshiba phone systems say "Toshiba" plus the description on the front cover. Example: "Toshiba Strata DK-280"
Not sure what you plan to change but programming can be quite difficult if you have no experience with it. It does depend a lot on which system you have. Many of the newest systems require special programming software.
Nov 13, 2007 | Toshiba DKT-2020 Corded Phone
Lands Phones Logo
949 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
